Intrto
This blueprint is what I use to control my smart lights using the Inovelli Smart switches. I have a few dimmers, an on off switch and a fan switch and this script works great for all 3 versions.
Description
To use this script you must link the 3 button events of your Inovelli smart switch in the Button Setup section. Unless you changed the event names they should match exactly with what is shown in the Button Section of this blueprint.
After that you can setup the actions that will be performed by the smart button when the buttons are pressed. You DO NOT need to set up all actions, only the actions you plan to use!
Compatibility
This blueprint is designed to work with the Inovelli white series switches.
Current this blueprint is known to work with the following switches.
- White Series Smart Dimmer (formerly 2-1 switch)
- White Series Smart Fan Switch
- White Series Smart On/Off Switch
Origian Script
The script is a tweak to [Skaronator’s IKEA BILRESA Dual Button blueprint] (IKEA Bilresa Dual Button Remote) so please support them as they did most of the hard work.
