Inovelli is shipping another round of innovative switches, the Zigbee Blue 2-1 seen here.
The switch features multi-press functions to trigger automations and a LED light bar that’s supposedly configurable to show notifications. For example, flashing red for when the garage door is open, etc.
I’m using Zigbee2Mqtt and I am able to configure the multi press functions, but I have yet to figure out how to utilize the LED to show notifications. I’m hoping someone smarter than me has the answer or a blueprint available soon.
I saw that discussion yesterday on the Inovelli forum, but I wasn’t sure if it works with Zigbee2mqtt. It is beyond my scope of yaml knowledge.
When I see code like that, I’m never sure where to paste it… in the configuration.yaml file, in an automation file? It’s a “cluster-you-know-what” to me.
I started on a script for LED effects through Z2M.
My blues have been delivered but I haven’t had the chance to install them yet so my script is incomplete.
Here is my script so far. It’s loosely based on the Inovelli Red script here: Inovelli Z-Wave Red Series Notification LED
It has selectors for LED#, Level, Color, Effect, and Duration.
LED#, Color, and Duration can accept the number value directly as well as the “friendly name”. The Effect value must be the “friendly name”.
This also supports selecting multiple switches to set at once.
The only possible issue is the device name (found in the MQTT device) of the switch entity needs to match the friendly name in Z2M.
If I have time, I might attempt to convert this into a blueprint.
Edit: Removed yaml, look below for link to my Github
