Install HAOS on a Raspberry Pi 4 using a USB-connected SATA SSD for boot
Hello -
I have a HA install booting from SD card on a Rpi4. I want to migrate the installation to a USB-connected SATA drive.
My plan was to install HAOS on the drive, then restore from a backup of my SD card installation.
To rule out some hardware-level problems, I AM able to install and boot the Raspberry Pi OS from this USB-connected drive, using the Raspberry Pi Imager software.
When I install HAOS via the Imager, it appears successful, but I am unable to connect to the HA UI (browser times out). I have given it hours to set itself up, so that is not the issue.
I do not have a micro HDMI cable available, so I can’t check for boot progress that way.
FWIW I have tried a few other things… bit -by-bit copy of the SD card to the HD for instance. I have also run the RPi bootloader (firmware) update and made sure the boot sequence is USB first, then sd card. When I leave both the SD card and the HD connected, it ends up booting from the SD card. In that configuration, it throws an error regarding a “duplicate installation” or similar.
Thanks in advance for any suggestions!
Curious on this as well. Did you find out what is the issue?
Funny, I’m getting ready to do the same thing. I’m on the forum for advice on a recommended SSD.
Anyway - Have you changed the boot order? Search “raspberry pi 4 ssd boot without sd card”, there are several explanations.
I hear ya that the Raspberry OS worked but HA on the SSD may have to be on the first boot.
I’m searching for answers too, just haven’t bought a SSD yet.
@Dmccr , @rpsalty ,
before I start a fresh install, do you have any feedback on how it ended for you ?
Thanks.
For the record, the procedure is publicly documented.
Raspberry Pi Imager allows to create an sdcard utility to enable boot on USB.
Then simply install the HAOS image on the USB drive with Raspberry PI imager.
