Hi, I am installing homeassistant in my raspberry pi 3, and it is failing. Can someone help me?
(homeassistant) homeassistant@raspberrypi:/srv/homeassistant $ python3 -m pip install homeassistant
Collecting homeassistant
Could not find a version that satisfies the requirement homeassistant (from versions: )
No matching distribution found for homeassistant
I’m on the full stretch version.
After following script from Dale3h n the post here (with docker) it comes up with an error when creating account.
"failed to fetch up“
Stretch Lite is the way foreward. Ensure you have the blank ssh file and the wpa_supplicant.conf file with your WiFi credentials in the /boot folder before you proceed with the Hass installation if you’re going the wireless route.
That link you posted originally works perfectly for Hass installation in the venv
Tried so many things now, I’m not sure anymore wich instruction works and wich not.
One is complaining about arm.
Other seems to work but messed up the name and IP-address resulting in multiple IP’s.
If I cannot find a way to delete last created IP and disable wifi I will do a clean install of rpi + pivpn and forget home-assistant.
Just start with a freshly formatted SD card. Download and write a Raspbian Stretch Lite image to your card. Prefigure your SD card for ssh and WiFi as I pointed out above and do the usual update/upgrade.
This way was my first attempt.
Fresh Stretch Full img boot from ssd.
Skipped the preparations for wifi and ssh.
Installed PiVPN.
On the RPi desktop I followed the instructions you link to.
It worked indeed (127.0.0.1:8123).
But there was no hassio in the panel on the left side.
Besides I did not manage to get it started as daemon (in next part of your link) my IP and name changed when I activated the Virtual Environment and the prompt changed.
