home-assistant.log
17-04-30 00:38:58 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/srv/homeassistant/lib/python3.4/site-packages/pyozwweb-0.4.0.31-py3.4.egg/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File "/usr/lib/python3.4/traceback.py", line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File "/usr/lib/python3.4/traceback.py", line 146, in _format_exception_iter
for value, tb in values:
File "/usr/lib/python3.4/traceback.py", line 125, in _iter_chain
context = exc.__context__
AttributeError: 'NoneType' object has no attribute '__context__'
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 192, in _async_setup_component
None, component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 253, in setup
CONF_CONFIG_PATH, default_zwave_config_path))
File "/srv/homeassistant/lib/python3.4/site-packages/pyozwweb-0.4.0.31-py3.4.egg/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyUSB0 : [\'Traceback (most recent call last):\\n\', \' File "/srv/homeassistant/lib/python3.4/site-packages/pyozwweb-0.4.0.31-py3.4.egg/openzwave/option.py", line 78, in __init__\\n raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \' File "/usr/lib/python3.4/traceback.py", line 181, in format_exception\\n return list(_format_exception_iter(etype, value, tb, limit, chain))\\n\', \' File "/usr/lib/python3.4/traceback.py", line 146, in _format_exception_iter\\n for value, tb in values:\\n\', \' File "/usr/lib/python3.4/traceback.py", line 125, in _iter_chain\\n context = exc.__context__\\n\', "AttributeError: \'NoneType\' object has no attribute \'__context__\'\\n"]'
17-04-30 01:00:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/discovery.py", line 117, in scan_devices
None, _discover, netdisco)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/discovery.py", line 143, in _discover
netdisco.scan()
File "/home/homeassistant/.homeassistant/deps/netdisco/discovery.py", line 63, in scan
self.gdm.scan()
File "/home/homeassistant/.homeassistant/deps/netdisco/gdm.py", line 21, in scan
self.update()
File "/home/homeassistant/.homeassistant/deps/netdisco/gdm.py", line 76, in update
sock.sendto(gdm_msg, (gdm_ip, gdm_port))
OSError: [Errno 101] Network is unreachable
