Installation woes of HAOS with VirtualBox
I tried creating a Virtualbox VM with HAOS using the provided vdi & instructions
Instructions I followed:
The machine was created successfully but I CANNOT get a successful first boot. There’s no VRDE session established or IP assigned but Virtualbox reports the machine is running. I currently have other VMs running on this system so it’s not a virtualbox configuration.
Please note that this is a headless installation on Ubuntu Server 22.04. I’m happy to migrate to 24.04 if there’s any known bugs but Ubuntu 22.04 is still supported.
$VBoxManage --version
7.0.20r163906
Please let me know if there are any logs or other info that would be of use troubleshooting this issue.
Edit #1: Here’s my installation script. I deleted everything and remade it to make sure this was completely accurate (note: I removed working directory & VRDE password for sake of privacy, they are set in the script I ran):
# Download VM image
HAOS_DOWNLOAD="https://github.com/home-assistant/operating-system/releases/download/13.2/haos_ova-13.2.vmdk.zip"
wget $HAOS_DOWNLOAD
#unzip image
unzip "haos_ova-13.2.vmdk.zip"
#Setup values
thisVM="HomeAssistant"
vmGroup="Infrastructure"
thisHddPath="${baseVMfolder}/${vmGroup}/${thisVM}/${thisVM}.vmdk"
# Create VM
VBoxManage createvm --name="${thisVM}" --basefolder="${baseVMfolder}"  --groups="/${vmGroup}" --ostype="Linux26_64" --register
#Move disk to VM folder
mv haos_ova-13.2.vmdk  $thisHddPath
VBoxManage storagectl "${thisVM}" --name "SATA Controller" --add sata --controller IntelAHCI
VBoxManage storageattach "${thisVM}" --storagectl "SATA Controller" --port 0 --device 0 --type hdd --medium "${thisHddPath}"
# Known changes
## Bridged networking
VBoxManage modifyvm "${thisVM}" --bridgeadapter1 enp5s0
## VRDE (remote desktop)
VBoxManage modifyvm "${thisVM}" --vrde on
VBoxManage modifyvm "${thisVM}" --vrdeport 3396
VBoxManage modifyvm ${thisVM} --vrdeproperty VNCPassword=**REDACTED**
## UEFI vs BIOS (stated in instructions on https://www.home-assistant.io/installation/alternative)
VBoxManage modifyvm  "${thisVM}" --firmware=efi
## HD Audio (stated in instructions on https://www.home-assistant.io/installation/alternative)
VBoxManage modifyvm "${thisVM}" --audio-controller=hda
If there is no VRDE session, then it is a VirtualBox issue.
This should be created before the VM starts up, so check everything again.
That’s why I included the information about other VMs running just fine, I don’t think it’s VirtualBox in general but likely a configuration with the specific VM. I probably won’t get a chance to clean up my commands to be a script until the weekend, but I’ll post the script when I do.
As promised, script is added to main comment. Please let me know if anything jumps out to you.
You are probably right that it is the configuration of the VM environment rather than HA, but what is wrong I do not know.
I avoid Windows hypervisors, because there are always fights with directly attached hardware configurations.
I was hoping there was some setting I was missing (like UEFI, except I got that one), that would be obvious.
Also, let’s not go throwing the “W” word around, this is hosted on Ubuntu Server. No Windows involved!
There is the requirement to disable secureboot.
Any chance you know how to do that in VirtualBox?
A quick search reveals a dated reddit post saying the way to switch off UEFI is to go to legacy/bios mode:
https://www.reddit.com/r/virtualbox/comments/o47un0/disable_uefi_secure_boot_in_virtualbox/
Looking at the manual the only mention I see (again from a quick search) is section 8.54 about modifying the signatures in the nvram file, which I think is the wrong path.
https://www.virtualbox.org/manual/ch08.html
Thanks for the link. TPM was the key phrase I was missing.
So translating the GUI walkthrough into CLI, I’ve added the following option:
--tpm-type= none
Unfortunately I still see no change. While they may have helped, there’s still some other issue going on.
