Buonasera non riesco a installare l’ultima versione di home assistant qualcuno può aiutarmi ?? Grazie ho la versione 2024.4.4 e sto cercando di passare alla versione 2024.5
Welcome to the forum!
You might not have read the guides on how to work here in this forum, so here it goes:
Before we begin…
This forum is not a helpdesk
The people here don’t work for Home Assistant, that’s an open source project. We are volunteering our free time to help others. Not all topics may get an answer, never mind one that helps you solve your problem.
[image]
This also isn’t a general home automation forum, this is a forum for Home Assistant and things related to it. Any question about Home Assistant, and about using things with Home Assistant, is welcome here. We can’t help you with e…
And if you can’t use english, see here
As explained in the FAQ this forum is an English language only forum. If you would prefer to converse in your native language rather than using a translator, there are a number of Home Assistant forums for non-English speakers:
French
German
Dutch
https://tweakers.net/tag/Homeassistant/forum/
Italian
Polish
Portuguese (Portugal)
Portuguese (Brazil)
Spanish
https://foro.domoticaencasa.es/
Danish
There are also a number of Facebook groups:
Denmark (12.5K members)
F…
penso che c’e una problema con 2024.5…ho avuto lo stesso problema…io vi sugerisco di aspettare per la prossima versione.
Edwin_D
(Edwin D.)
May 2, 2024, 7:38pm
4
אני לא חושב שהגרסה הבאה תשנה משהו. אבל האנשים שיודעים הכי הרבה לא מדברים איטלקית…
EDIT: I am afraid just waiting for the new version to fix it won’t help. But most people here do not speak Italian.
Do you get any error messages, is there something in the logs? Also look in home-assisant.log.1 as that holds the log previous boot.
Spiro
May 2, 2024, 7:52pm
6
Eble ĝi pliboniĝos kun 2024.5.1
Godkväll, jag har inte installerat den ännu men väntar ett par releaser innan det blir dags.
Iets anders gebruiken dan Engels is niet toegestaan, maar deze post maakt me aan het lachen
I have pretty limited italian, I was just trying to be helpful since I seemed to have the same issue. It seems like there is a solution, or at least one integration had been identified that is causing issues…
Hai il integration Dreame Vacuum? C’e una problema e il integration non funzione su 2024.5…Devi disattivare il integration prima di il upgrade. C’e un thread su Github…
opened 09:07AM - 02 May 24 UTC
bug
question
**Describe the bug**
After upgrade to 2024.5.0, Dreame Vacuum integration is st… alling HA startup sequence.
I have no additional info to share because as HA was restarting in a loop it was difficult to retrieve any evidence.
Only evidence I can share is that, during the 30 seconds window in which the UI was available, in the startup norification message at the bottom left of the browser, Dreame Vaccum was the last custom integration to be loaded before the system crashed.
I managed to disable the integration during the 30 seconds window and now the system is up and running without problems.
Also in the console of the machine running HA, there was a general error for out of memory prior to the reboot.
**To Reproduce**
Upgrade HA to 2024.5.0
**Expected behavior**
I was expecting HA to startup and Dreame caused a reboot loop
Se non hai Dreame Vacuum, non so la problema. Spero che questo e utile!
tom_l
May 3, 2024, 1:08am
12
AS has been previously noted this is an English language only forum. Please do not use anything other than English.
