I also understood that for custom components, they’d define their requirements in a manifest.json file, which then can be used by the core home assistant service to install the required dependencies. Before that’d be in that /config/deps folder, but I’m not so sure about that anymore.
The practical issue I’m facing is that I use a 3rd party custom component which used to work OK, but since a recent update (2022.07.3) it complains about one of those dependencies from the custom component no longer being there (https://github.com/ollo69/ha-smartthinq-sensors/issues/353 for more details).
At this point, I figure the issue is not so much the custom component but more the behavior of home assistant and the dependencies.
My specific setup uses the containerized home assistant core version + https://k3s.io/ for managing the containers. The only folder which is retained between container switches is the /config folder, which means that it works OK if the dependencies are kept in /config/deps, but not if they’d be installed into another folder.
Are there any documented details about how dependencies for custom components are supposed to work?
Any word on this? I am facing the same issue. It seems that HA is not installing the requirements that I have specified in my manifest.json. It was working fine up until the last HA Core update, and now it’s back to this error - frustrating!
System Log:
2023-10-25 13:16:50.438 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration soundtouchplus: Unable to import component: cannot import name 'WebSocketApp' from 'websocket' (/usr/local/lib/python3.11/site-packages/websocket/__init__.py)
File "/config/custom_components/soundtouchplus/__init__.py", line 9, in <module>
2023-10-25 13:16:51.536 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration soundtouchplus: cannot import name 'WebSocketApp' from 'websocket' (/usr/local/lib/python3.11/site-packages/websocket/__init__.py)
2023-10-25 13:16:51.537 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration soundtouchplus: cannot import name 'WebSocketApp' from 'websocket' (/usr/local/lib/python3.11/site-packages/websocket/__init__.py)
It’s been a long time since I did look into this issue so I don’t fully recall what the exact issue was.
I think there was also a change with the specific custom integration I was using that required me to reauthorize – basically not really an issue in HA itself.
I think it might be the websocket entry in your manifest.json. there is a websocket library on pypi which i do not think you should be installing and this is maybe causing a conflict with the websocket-client which is what your integration is expecing when importing WebSocketApp.
You will need to remove the websocket entry but also uninstall that library in your HA environment.
I’m fairly new to the websocket library, learning Python, and learning HA as well. I thought I had read somewhere that the “websocket” library was required if using “websocket-client”. To be honest, I have tried so many different things to fix this that I’m wondering which way is up!
I will give your suggestion a try, and let you know how it goes.
Hi Mark. Just wanted to let you (and future readers) know that the addition of “websocket” was the problem when trying to use “websocket-client”. I removed the “websocket” entry from requirements, and it is now working like a charm.
Thanks again for pointing me in the right direction.
