I don’t think it’s a general problem. I had ha vm on a proxmox server. There it works.
Have a skyconnect and give it a try, but the skyconnect work’s in the past not so fine with zigbee2mqtt
That’s great news! Did it simply work after you set up the passthrough in TrueNAS? Did you need any extra steps like blacklisting a kernel module?
Will you share which USB controller type you have selected in TrueNAS?
This morning, I sorta got the ConBee II working…
Credit to the following thread…
I’m not sure how useable this will be on TrueNAS but it does work. I don’t use ZigBee myself but I can write a little script someone can use if they want to try it.
Please see the next post for another solution
your script is really, really cool. i’m really new to TNS (and kinda new to HA now that i think about it)…
anyway, i i kinda stumbled on a way to do it without having to use a script. disclaimer: i don’t really know how i would’ve even gotten a script to run in TrueNAS Scale…i barely understand SSH to begin with
anyway, here’s what I did:
in the TrueNAS Scale shell, run:
ls /dev/serial*
note the output at the bottom: pci-000…
*if you aren’t seeing something like the above, see edit below -
In TrueNAS Scale, go to Virtualization → VM → Devices
Add
select: Type: PCI Passthrough Device
From the PCI Passthrough Device, pick the one you noted earlier (will probably be something different for you, but here’s what it looked like for me)
- Not sure if the order number (1002, 1003, 04, etc.) matters.
- If it does, try setting the Conbee to start up before the DISK
(note: I tried both ways, it didn’t matter for me either way)
this is what my thing ended up looking like:
This next part is really important:
Power Off the VM (don’t just Restart it via HA, actually shut it down from TrueNAS Scale’s VM management portal).
Then Start it.
profit
edit:
i pulled a graphics card out of the machine that i wasn’t going to be using on there anymore and the ConBee passthrough broke. fortunately, i documented what i had to do to get it working
unfortunately, when i was running the ls /dev/serial*
command through TNS’s Shell, it wasn’t outputting anything anymore for some reason.
super annoying.
so, if for some reason you’re seeing something like that (e.g., nothing?), then do this:
ls /dev/serial/by-id
ls /dev/serial/by-path
ta-da! now I (& maybe one of you?) will know what to passthrough again!
Thank you for sharing! This is way better (correctness and convenience) than using a script. The only thing I would change is to recommend using the Stop button instead of Power Off.
My understanding is that Stop should issue a proper shutdown of the VM, while Power Off is like ripping the plug from wall.
thanks for the heads up–good to know
Thanks @troy!
This worked for me using:
TrueNAS Scale 22.12.1
Sonoff Zigbee 3.0 USB Dongle Plus
- USB Passthrough Device
- Controller Type: qemu-xhci
- Device: usb_1_11 CP210x UART Bridge (Silicon Labs)
- Device Order: 1002
Hi everyone, sorry if my message comes out of this thread but it very close.
I trying configure Wi-Fi onboard wi-fi inside HAOS. Inside TrueNas i make PCI Passthru with Wi-Fi mobo but HAOS doesn’t found it. What possible to do with it?
Hi @NAGL95 - I’m not sure if what your trying to do will be supported, and it will undoubtedly be an edge case if it is. The usual response for any server setup is, don’t use WiFi. I don’t want to discourage you, but finding someone successfully using WiFi as the primary connection to Home Assistant may be challenging.
I noticed you made s separate post several days ago, but still no response. I would also try asking on Discord if you’re a member there. First, you should confirm if what you want to do is possible in HAOS.
Sorry I can’t be more helpful with your issue.
I don’t know if this is the right thread.
But have someone the problem, if the vm start/restart,that the addons where not loaded?
I’m not sure @daschmidt - Please confirm that each add-on has Start on boot enabled.
Thank you so much for this writeup, this really helped me solve an issue with my VM on Truenas.
In case anyone else is having similar issues to me I will describe the issues I was having. I created my Home Assistant VM on Truenas and moved my Home Assistant instance without understanding all of the settings. My VM seemed to be working fine but I was having some trouble with some add ons and the HomeKit integration. My AirSonos add on would stop working after someone tried to play music on a speaker. I have several HomeKit bridges configured and when I reconfigured one of them I was no longer able to add it to the Home app. This was really driving me crazy and all signs seemed to be pointing to some type of network issue. After reading this post I created a test installation and by turning on “Trust Guest Filters” I was able to use AirSonos and connect to HomeKit bridges. I did not create a bridge NIC but did use the VirtIO adapter type.
After recreating my VM using this posts guidelines everything seems to be working so far. Hopefully someone else having issues similar to me can benefit from this great post.
the problem is, that the Addon’s in the submenu is not listet settings->addons.
I got this error ever time i try to pass through my conbee 2
group 10 is not viable
Please ensure all devices within the iommu_group are bound to their vfio bus driver.
I’m running into an issue with DNS. My router is configured to use pihole, which is running as a docker app on TrueNAS. I’m guessing the issue is that HOAS can’t roundtrip to PiHole out of the same network interface.
I’ve tried updating the DNS nameserver using this guide, but none of the options stuck. “resolution info” still shows DNS errors and “network info” still shows the pihole is being used as the nameserver.
Does anyone have a way around this?
I was able to create a Home Assistant VM successfully. I started it up and imported my most recent full backup.
This brought in my data successfully. I was immediately able to use devices with HomeKit!
However, my add-ons were not set up or configured. I tried adding them manually but many of them don’t start up.
I followed the multiple backup restore process from @fedot on this page and that appears to have worked for me.
It appears my add-ons are installed (including the ones I didn’t install manually, or that were from third-party repositories, like Shortumation and Google Drive Backup), configured, and successfully start up.
Works great!
