thanks for your quide! Unfiertunately I get stuck right at the beginning when it asks me to select a storage pool. It does detect my pool but pressing enter does absolutely nothing. Any clue what I can check or how I can solve this?
Update: I disabled the cifs pool temporarily as I donβt have any containers or disk images there anyway to force the installer on the lvmthin and it workedβ¦ I got βcompleted successfullyβ
Something is going on with that but not sure what - let me know if you want to troubleshoot anything
I followed this really great guide to setting everything up and it worked great! Except for when the VM restarts, then I get a βa start job is running for wait until kernel time synchronizedβ making the system start wait for a 90 second timer before continuing.
I have seen other posts with this issue but havenβt found a solution to it.
I hadnβt seen that one, the discussion revolves around network not being up at that point in time. But according to my start logs the Network Manager Wait Online finishes correctly.
In the logs I can see starting, stopping and starting Network Time Synchronisation again.
Do not know what this mean exactly, but I suspect this βonlineβ is not the same as βHAOS can now talk to internet freely.β
β¦ which is what the network time sync needed.
first time using proxmox and wanting to try out ceph as well
myplan is to get HA onto the laptop and start shutting down the servers as I only have a few hours to actually be on the pc hardly worth wasting 20kw running them
How many available cores do you have?
It would appear that the machine youβre trying to use is a single core cpu.
Describe your system (laptop) I noticed in your first post that you were using BTRFS on PVE 7.2-7, and in this one your using EXT4 on PVE 7.2-3
all good stumbled across the menu that allowed changes to be made before it downloaded HA
currently using ZFS as this seems to be the only way for replication to work ,
think I have now reinstalled a dozen times
still unsure why I can never get the nodes to sync ,
not even 10 mins and it died on me
looks like you still need 3 machines for it to work so I might start renting a OVH seed box again for off site backups , hopefully they have now allowed VMβs in their biosβ only reason I stopped using them
thinking of going to the βHome Assistant Container LXCβ route
only downside is I can not do a simple import from a backup
but hell it barely uses RAM / CPU
