How did the update to OS 9 go?
thanks for checking! I havenβt done it yet, (didnβt even now it was out). Iβll try tonight and see how it goes and let you know.
The HA Team just made a Revert βBump stable channel Home Assistant OS to 9.0β so you may have to wait for an update.
Edit: They just made a Revert "Revert βBump stable channel Home Assistant OS to 9.0"β
OS 9 is a go, again
It looked like it worked. I had removed some hardware but hadnβt shutdown/rebooted the VM so it had USB errors after the install and reboot, so I had to shut it down and reboot.
So, allβs well now!
Worked fine for me!
Hi
Iβm facing same issue and tried just 1 hour ago to update rom 8.5 to 9.0 but I still get stuck.
As I read from your message, it should be all working after
Edit: They just made a Revert βRevert βBump stable channel Home Assistant OS to 9.0ββ
OS 9 is a go, again
Should I do anything before or after the update process?
The conversation between patmann03 and I starts here of trying to solve their issue of getting stuck after OS updates. Your issue may be totally different.
If you installed HAOS using a script from this guide before May 3 2022, Iβd suggest doing this.
I havenβt used your script, but I used this script to create the HA VM.
I will try to check messages in this thread to see if itβs valid also for my issue
Pretty sure that is the script I used as well about a year or so ago. I do think taking a backup and rebuilding the VM with this script worked. I will know for sure next OS update.
Hi
Iβm trying to create a new HA VM due to an issue updating my VM from HA OS 8.5 to 9.0
But Iβm getting this error
Creating a HAOS VM using the above advanced settings
β Using local-lvm for Storage Location.
β Virtual Machine ID is 100.
β https://github.com/home-assistant/operating-system/releases/download/9.0/haos_ova-9.0.qcow2.xz
β Downloaded haos_ova-9.0.qcow2.xz
β Extracted KVM Disk Image
- Creating HAOS VM...400 Parameter verification failed.
name: invalid format - value does not look like a valid DNS name
qm create <vmid> [OPTIONS]
βΌ ERROR 255@268 Unknown failure occurred.
It seems something related to DNS
this is my DNS configuration in Proxmox
I havenβt used default settings in the script, to enter the MAC address of the other VM and I choose not to start the new VM automatically.
The script Iβm using is
bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/vm/haos-vm-v4.sh)"
What else should I check?
What did you use for the hostname?
I used HA_OS
underscore isnβt allowed
HA-OS is ok, right?
yes, it will set it as βha-osβ
Everything worked fine.
After the script, Iβve restored the backup from the original VM and it seems to work fine.
I will wait for a couple of days before deleting the original HA VM.
PS: Do you know any script or method to create a Node-RED LXC container in Proxmox?
Iβve updated my Proxmox from 6.x to 7.2 today and got the problem, that my hassos vm is not starting. After googling a bit, I suspect I need to disable secure boot but the problem is that I cant see anything in the consoleβ¦
It just stays black, I even tried to setup a new vm but that doesnβt work either. Any idea how I can disable that?
Nevermind, apparently I just had to restart the whole server
