Sorry if this question is already answered, butI have searched the forums and the Discord channels, but I got nowhere closer the solution yet.
So: I have tried to install Home Assistant (Supervised) to a NUC, but I can’t make it work from the docs.
I therefore ended up with a Debian / Home Assistant which works great, but since I’m a total Linux noob, that’s not my preferred way.
So from todays announcement, I thought I should make it work and maybe clarify the docs since I guess there are more like me out there.
But to do that, I need help to make it work at first
The docs says:
2. Install Home Assistant:
Flash the downloaded image to an SD card using balenaEtcher. If using a Pi, we recommend at least a 32 GB SD card to avoid running out of space. On Virtual machine platforms, provide at least 32 GB of disk space for the VM.
I have tried the Pi/SDcard install which is super smooth, but is this valid for NUC as well?
Coming from a Windows/PC-world I am used to make a bootable USB-drive, boot from that, select the target (NUC SSD-drive) and just Enter-Enter my way forward.
I got no problem flashing the NUC image to the USB, but when booting from it I got 4 options that says something like this:
- Auto-install
- OS 1
- OS 2
- Shell
And none of them gets me anywhere near an installation, so I guess other steps are needed.
Suggestions?
Is this the place to go on or should I open a forum thread instead?
