I’ve just installed home assistant as VM in Proxmox using the (KVM proxmox)
The first thing I wanted to do was to install wireguard and setup this machien as a client so I can access it over the internet and bypass CGNAT from my ISP.
Tried add terminal with ssh add-on and installed wireguard on it using
apk add -U wireguard-tools
but I noticed that wireguard was gone after rebooting home assistant. I’ve been reading a bit and found out the add-ons are docker containers (i’m pretty new to docker so please forgive my ignorance) and not in the host. I understand that home assistant is also running in a docker container but what I’m trying to do is ssh into the host machine itself and not any of the docker containers.
I also tried via proxmox and launching the console. It gives me a cli as ha (that’s what it shows). I execute login and become root user but apk is not available. I also tried apt-get and no luck.
Wireguard will not circumvent your CGNAT.
It is a service that runs on your local HA machine and it will be behind the CGNAT.
In order to circumvent the CGNAT you need to have a server somewhere on the internet to act as a interconnection point for your internal and external connections.
It could be a Cloudflare tunnel, but there are other solutions too.
Yes sorry. I forgot to mention that I do have a wireguard setup as a server somewhere on the cloud where some of my devices (mobile, other servers etc) connects to.
Thanks. I’ve actually seen this before but tried to hold off on using it since I was trying to find a way to login as root and install packages. This add-on does solve my concern on wireguard but for other packages that I may want to install, not so much. But it did give me an idea that instead of installing packages as root, maybe create an add-on instead.
