Hi everyone. I’m brand new to the Home Assistant ecosystem but I’m really enjoying what I’ve learned and tinkered with so far. Well done to all involved in HA’s development, and thanks especially to @teharris1 for their work on the Insteon integration—I had given up several years ago on ever getting my Insteon purchases working nicely, but now might finally be the time.
Setup: I’m running Home Assistant 2021.5.5 in a Docker container on my Synology NAS, and I have the Insteon integration set up with my 2012 Hub (2242-522), several RemoteLinc Mini Remotes (2444A3, 2444A2xx4), several plug-in relays (2633-522), and several micro relays (2443-522).
Goal: My goal is for the states of all devices attached off the relays to be correctly reported by HA, and for the Insteon remotes to perform a combination of direct Insteon device control (i.e. direct linking between the remote and a device) and generation of events that HA can detect (and therefore trigger effects on non-Insteon equipment).
What’s working: I can correctly trigger Insteon device state changes through the HA user interface, and HA correctly detects (and reports) state changes made at the devices’ direct switches (wired wall switches, inbuilt buttons on the plug relays).
What’s not working yet: My HA dashboard isn’t detecting some changes in state triggered externally to HA—that is, HA isn’t detecting a relay being switched on or off by its linked remote.
What I’ve tried:
- I’ve updated to the currently latest available version of HA, from 2021.5.3 to 2021.5.5.
- I’ve activated
DEBUG
logging forpyinsteon
andhomeassistant.components.insteon
in an attempt to identify any obvious problems, and captured logs of some key activities below. - I’ve searched these forums for others experiencing the same issue. @mrdrennan did, and it was resolved in their case by ensuring that the linkings between the PLM (a.k.a. Hub?) and the switches were all two-way. I’m pretty sure from the debug logging that this is already the case for me, but I’ve got a picture below of what HouseLinc says about the remote.
- I’ve used HouseLinc to generate a “Half-Link” report. There are no half-links.
What else might be relevant: I didn’t have any success with auto-discovery of Insteon devices, so I’ve added manual “overrides” for all of the devices I’m interested in.
Thank you in advance for any ideas or assistance you might be able to offer in getting this corrected.
What's logged when I turn my light on using HA
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: send.on.direct data: {'address': 271115, 'on_level': 255, 'group': 1}
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.on.direct data: {'msg': msg_id: 0x62, address: 271115, flags: 0x00, cmd1: 0x11, cmd2: 0xff, 'priority': 3}
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 271115, flags: 0x00, cmd1: 0x11, cmd2: 0xff
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02622711150011ff06
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 271115, flags: 0x00, cmd1: 0x11, cmd2: 0xff, ack: 0x06
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.271115.1.on.direct data: {'cmd1': 17, 'cmd2': 255, 'user_data': None}
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 0250271115266c9c2011ff0250271115266c9c2011ff
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 271115, target: 266c9c, flags: 0x20, cmd1: 0x11, cmd2: 0xff
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: 271115.on.direct_ack data: {'cmd1': 17, 'cmd2': 255, 'target': 266c9c, 'user_data': None, 'hops_left': 0}
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.271115.1.on.direct data: {'on_level': 255}
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: state_271115_on_off_switch_1 data: {'name': 'on_off_switch', 'address': '271115', 'value': 255, 'group': 1}
2021-05-30 14:30:31 DEBUG (MainThread) [homeassistant.components.insteon.insteon_entity] Received update for device 271115 group 1 value 255
2021-05-30 14:30:31 DEBUG (MainThread) [pyinsteon.topics] Topic: event_271115_1_on_event data: {'name': 'on_event', 'address': '271115', 'group': 1, 'button': 'on_off_switch'}
2021-05-30 14:30:31 DEBUG (MainThread) [homeassistant.components.insteon.utils] Firing event insteon.button_on with {'address': '271115'}
2021-05-30 14:30:33 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
What's logged when I turn my light off using HA
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.topics] Topic: send.off.direct data: {'address': 271115, 'group': 1}
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.off.direct data: {'msg': msg_id: 0x62, address: 271115, flags: 0x00, cmd1: 0x13, cmd2: 0x00, 'priority': 3}
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 271115, flags: 0x00, cmd1: 0x13, cmd2: 0x00
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 026227111500130006
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 271115, flags: 0x00, cmd1: 0x13, cmd2: 0x00, ack: 0x06
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.271115.1.off.direct data: {'cmd1': 19, 'cmd2': 0, 'user_data': None}
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 0250271115266c9c2013000250271115266c9c201300
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 271115, target: 266c9c, flags: 0x20, cmd1: 0x13, cmd2: 0x00
2021-05-30 14:31:09 DEBUG (MainThread) [pyinsteon.topics] Topic: 271115.off.direct_ack data: {'cmd1': 19, 'cmd2': 0, 'target': 266c9c, 'user_data': None, 'hops_left': 0}
2021-05-30 14:31:10 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
What's logged when I turn my light on at the switch (HA doesn't seem to detect this)
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61000001cf1100
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 000001, flags: 0xcf, cmd1: 0x11, cmd2: 0x00
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.on.all_link_broadcast data: {'cmd1': 17, 'cmd2': 0, 'target': 000001, 'user_data': None, 'hops_left': 3}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.device_types.battery_base] We have commands to run so let's get to it
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.1c4c61.1.on.all_link_broadcast data: {'on_level': 255}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: subscriber_1c4c61_on_1_broadcast data: {'on_level': 255}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: event_1c4c61_1_on_event data: {'name': 'on_event', 'address': '1c4c61', 'group': 1, 'button': 'on_off_switch_a'}
2021-05-30 14:33:49 DEBUG (MainThread) [homeassistant.components.insteon.utils] Firing event insteon.button_on with {'address': '1c4c61', 'button': 'a'}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: send.extended_get_set.direct data: {'address': 1c4c61, 'priority': 5, 'data1': 0, 'data2': 4, 'data3': 255, 'data4': 0, 'data5': 0, 'data6': 0, 'data7': 0, 'data8': 0, 'data9': 0, 'data10': 0, 'data11': 0, 'data12': 0, 'data13': 0, 'data14': 0}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.extended_get_set data: {'msg': msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, 'priority': 5}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 1515
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] Message less than 2 bytes
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 151502501c4c61000001cf1100
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61266c9c411101
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 266c9c, flags: 0x41, cmd1: 0x11, cmd2: 0x01
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.on.all_link_cleanup data: {'cmd1': 17, 'cmd2': 1, 'target': 266c9c, 'user_data': None, 'hops_left': 0}
2021-05-30 14:33:49 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.1c4c61.1.on.all_link_cleanup data: {}
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61110201cf0600
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 110201, flags: 0xcf, cmd1: 0x06, cmd2: 0x00
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.all_link_cleanup_status_report.all_link_broadcast data: {'cmd1': 6, 'cmd2': 0, 'target': 110201, 'user_data': None, 'hops_left': 3}
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61110201cb0600
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 110201, flags: 0xcb, cmd1: 0x06, cmd2: 0x00
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.all_link_cleanup_status_report.all_link_broadcast data: {'cmd1': 6, 'cmd2': 0, 'target': 110201, 'user_data': None, 'hops_left': 2}
2021-05-30 14:33:50 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
2021-05-30 14:33:57 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Keep awake result: unsent
2021-05-30 14:33:57 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Retries: 2
2021-05-30 14:34:00 DEBUG (MainThread) [pyinsteon.topics] Topic: send.extended_get_set.direct data: {'address': 1c4c61, 'priority': 5, 'data1': 0, 'data2': 4, 'data3': 255, 'data4': 0, 'data5': 0, 'data6': 0, 'data7': 0, 'data8': 0, 'data9': 0, 'data10': 0, 'data11': 0, 'data12': 0, 'data13': 0, 'data14': 0}
2021-05-30 14:34:00 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.extended_get_set data: {'msg': msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, 'priority': 5}
2021-05-30 14:34:00 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf
2021-05-30 14:34:00 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02621c4c61102e000004ff00000000000000000000cf06
2021-05-30 14:34:00 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, ack: 0x06
2021-05-30 14:34:00 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.1c4c61.extended_get_set.direct data: {'cmd1': 46, 'cmd2': 0, 'user_data': 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf}
2021-05-30 14:34:01 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
2021-05-30 14:34:03 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Keep awake result: failure
2021-05-30 14:34:03 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Retries: 1
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.topics] Topic: send.extended_get_set.direct data: {'address': 1c4c61, 'priority': 5, 'data1': 0, 'data2': 4, 'data3': 255, 'data4': 0, 'data5': 0, 'data6': 0, 'data7': 0, 'data8': 0, 'data9': 0, 'data10': 0, 'data11': 0, 'data12': 0, 'data13': 0, 'data14': 0}
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.extended_get_set data: {'msg': msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, 'priority': 5}
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 0262
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] Full message not received
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02621c4c61102e000004ff00000000000000000000
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] Message too short
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02621c4c61102e000004ff00000000000000000000cf06
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, ack: 0x06
2021-05-30 14:34:06 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.1c4c61.extended_get_set.direct data: {'cmd1': 46, 'cmd2': 0, 'user_data': 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf}
2021-05-30 14:34:07 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
2021-05-30 14:34:09 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Keep awake result: failure
2021-05-30 14:34:09 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Retries: 0
What's logged when I turn my light off at the switch (HA doesn't seem to detect this)
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61000001cf1300
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 000001, flags: 0xcf, cmd1: 0x13, cmd2: 0x00
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.off.all_link_broadcast data: {'cmd1': 19, 'cmd2': 0, 'target': 000001, 'user_data': None, 'hops_left': 3}
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.device_types.battery_base] We have commands to run so let's get to it
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.extended_get_set data: {'msg': msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, 'priority': 5}
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 1515
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] Message less than 2 bytes
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 151502501c4c61000001cf1300
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61266c9c451301
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 266c9c, flags: 0x45, cmd1: 0x13, cmd2: 0x01
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.off.all_link_cleanup data: {'cmd1': 19, 'cmd2': 1, 'target': 266c9c, 'user_data': None, 'hops_left': 1}
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.topics] Topic: handler.1c4c61.1.off.all_link_cleanup data: {}
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61130201cf0600
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 130201, flags: 0xcf, cmd1: 0x06, cmd2: 0x00
2021-05-30 14:34:28 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.all_link_cleanup_status_report.all_link_broadcast data: {'cmd1': 6, 'cmd2': 0, 'target': 130201, 'user_data': None, 'hops_left': 3}
2021-05-30 14:34:29 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02501c4c61130201cf0600
2021-05-30 14:34:29 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x50, address: 1c4c61, target: 130201, flags: 0xcf, cmd1: 0x06, cmd2: 0x00
2021-05-30 14:34:29 DEBUG (MainThread) [pyinsteon.topics] Topic: 1c4c61.1.all_link_cleanup_status_report.all_link_broadcast data: {'cmd1': 6, 'cmd2': 0, 'target': 130201, 'user_data': None, 'hops_left': 3}
2021-05-30 14:34:29 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
2021-05-30 14:34:36 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Keep awake result: unsent
2021-05-30 14:34:36 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Retries: 2
2021-05-30 14:34:39 DEBUG (MainThread) [pyinsteon.topics] Topic: send.extended_get_set.direct data: {'address': 1c4c61, 'priority': 5, 'data1': 0, 'data2': 4, 'data3': 255, 'data4': 0, 'data5': 0, 'data6': 0, 'data7': 0, 'data8': 0, 'data9': 0, 'data10': 0, 'data11': 0, 'data12': 0, 'data13': 0, 'data14': 0}
2021-05-30 14:34:39 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.extended_get_set data: {'msg': msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, 'priority': 5}
2021-05-30 14:34:39 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf
2021-05-30 14:34:39 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02621c4c61102e000004ff00000000000000000000cf06
2021-05-30 14:34:39 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, ack: 0x06
2021-05-30 14:34:39 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.1c4c61.extended_get_set.direct data: {'cmd1': 46, 'cmd2': 0, 'user_data': 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf}
2021-05-30 14:34:40 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
2021-05-30 14:34:42 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Keep awake result: failure
2021-05-30 14:34:42 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Retries: 1
2021-05-30 14:34:45 DEBUG (MainThread) [pyinsteon.topics] Topic: send.extended_get_set.direct data: {'address': 1c4c61, 'priority': 5, 'data1': 0, 'data2': 4, 'data3': 255, 'data4': 0, 'data5': 0, 'data6': 0, 'data7': 0, 'data8': 0, 'data9': 0, 'data10': 0, 'data11': 0, 'data12': 0, 'data13': 0, 'data14': 0}
2021-05-30 14:34:45 DEBUG (MainThread) [pyinsteon.topics] Topic: send_message.extended_get_set data: {'msg': msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, 'priority': 5}
2021-05-30 14:34:45 DEBUG (MainThread) [pyinsteon.messages] TX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf
2021-05-30 14:34:45 DEBUG (MainThread) [pyinsteon.protocol.messages.inbound] IN CREATE: 02621c4c61102e000004ff00000000000000000000cf06
2021-05-30 14:34:45 DEBUG (MainThread) [pyinsteon.messages] RX: msg_id: 0x62, address: 1c4c61, flags: 0x10, cmd1: 0x2e, cmd2: 0x00, user_data: 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf, ack: 0x06
2021-05-30 14:34:45 DEBUG (MainThread) [pyinsteon.topics] Topic: ack.1c4c61.extended_get_set.direct data: {'cmd1': 46, 'cmd2': 0, 'user_data': 00.04.ff.00.00.00.00.00.00.00.00.00.00.cf}
2021-05-30 14:34:46 DEBUG (MainThread) [pyinsteon.protocol.protocol] Started
2021-05-30 14:34:48 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Keep awake result: failure
2021-05-30 14:34:48 DEBUG (MainThread) [pyinsteon.device_types.battery_base] Retries: 0
