Insteon Hub or PLM?
Take a look through the included example file. It provides all the samples you need:
@Juggler there’s nothing in there that announces the devices to the homeassistant mqtt autodiscovery topic (e.g. homeassistant/<component_type>/<unique_id>/config). Do you have an example showing the config topic and message for each device?
fan.yaml
- platform: mqtt
  name: "livingroom fanlinc fan"
  command_topic: 'insteon/aa.bb.cc/fan/set'
  state_topic: 'insteon/aa.bb.cc/fan/state'
  percentage_command_topic: 'insteon/aa.bb.cc/fan/speed/set'
  percentage_command_template: >
      {% if value == 1 %}
         low
      {% elif value == 2 %}
         medium
      {% elif value == 3 %}
        high
      {% endif %}
  percentage_state_topic: 'insteon/aa.bb.cc/fan/speed/state'
  percentage_value_template: >
      {% if value == 'low' %}
        33
      {% elif value == 'medium' %}
        67
      {% elif value == 'high' %}
        100
      {% else %}
        0
      {% endif %}
  speed_range_min: 1
  speed_range_max: 3
light.yaml
- platform: mqtt
  schema: json
  name: "bar pendant lights"
  state_topic: "insteon/aa.bb.cc/state"
  command_topic: "insteon/aa.bb.cc/level"
  brightness: true
switch.yaml
- platform: mqtt
  name: "basement bathroom pots"
  state_topic: 'insteon/aa.bb.cc/state'
  command_topic: 'insteon/aa.bb.cc/set'
  value_template: "{{ value_json.state }}"
- platform: mqtt
  name: "closet outlet top"
  state_topic: 'insteon/aa.bb.cc/state/1'
  command_topic: 'insteon/aa.bb.cc/set/1'
Looks like autodiscovery is coming soon! MQTT discovery automatic configuration · Issue #128 · TD22057/insteon-mqtt · GitHub
Is this MQTT better than integrated Insteon support?
