Just completed a very simple and effective way to integrate my old style (ding-dong) doorbell with my HA, and wanted to share.
I work from home, have my office upstairs, sometimes when I am playing music, I do not hear my doorbell. So I have been looking into adding a second chime.
I have been using Xiaomi sensors through-out the house for temperature/humidity monitoring, as well as some wireless switches.
Old style doorbells use electro-magnets to pull the pistons in, a spring return plunges them into the tone bars. A door/window contact uses a reed contact, activated by a permanent magnet to indicate status.
The electro-magnet in a doorbell is strong enough to active this read-contact. So I purchased a Xiaomi wireless door sensor, that fitted snugly into my doorbell housing.
I use a Xiaomi gateway for the second chime. The gateway is integrated into HA, so with the status signal I also added an e-mail notification with camera snapshot.
I had to ādebounceā the signal (it is activated twice), but all in all this was a very cheap and easy way to extend functionality, without any wiring/soldering.
If anyone is interested in any code, please let me know.
I might give this a try as well.
My button solution has the drawback that it sometimes gets triggered when someone turns the outside lights on or off. Guess the relay is a little too sensitive.
Just got the Xiaomi aquare gateway but got f*ed since its V2 so need to find how to mod it to work with HA. I also bought a mini wireless switch which Iām not a fan of since it uses batteriesā¦
Oh nice! So managed to add my V2 gateway into HA. Will see if I like the look of the xiaomi mini switch as a doorbell (round a slightly bigger than my original doorbell). Was thinking of wiring it to a 3V transformer later onā¦
But might consider your setup if I donāt like how things goā¦
Yes thatās pretty much it. I use the signal in hass to send me an email notification with a screenshot. The second chime I can actually hear upstairs :).
The door sensor is actually triggered by the electro magnet in the plunger.
Thanks for your great suggestion, I had a spare xiaomi door sensor sitting around and now I have it affixed with blutack inside my front door bell. I took off the plastic casing to make it fit better, it turns out the sensors are really tiny.
My method of dealing with the ādebounceā is a bit hacky: Iāve an automation monitoring the sensor for state switches to āoffā, which switches an input Boolean to āonā for a few seconds (added a delay in the automation) and then switches it back to off. Then I setup a virtual binary sensor to monitor the state of the input Boolean in order to give me a ācleanā binary sensor for use in other automationsā¦
At the moment I have automations to send me a snapshot from the driveway camera if Iām out of the house, and to send a snapshot to whichever android tvs are turned on in the house.
My code below copied from reddit, sorry for formatting. Am on mobile.
Sure!
ā
So in my case, I use it for my door bell. I get several pulses when the doorbell is rang.
So automation is called, and does what it is supposed to do. After that it calls a script, that will block the automation from being called (5 seconds in my case).
I think so, looks like the shiny metal part is attracted by the electromagnet. Pretty sure it would influence the reed switch in the Xiaomi contact. It may be oscillating, if so you can expect multiple triggers, but that can be negated with the code posted earlier .
That sucks, maybe the shielding is the problem? Any way of removing that? Or maybe try to take the unit from the wall to test if it works from the back?
I cut the metal and placed it at the top. When the doorbell rings itās turns the state to off but it doesnāt set it back to on. I have to use the xiaomi magnet to reset it.
