I have problem to integrate my BECKER R8/17 C PROF Motors.
I have as controllers :
- One master EC541-II for each motor
- One EC545-II For zones
- One EC3111 set as general
I’ve got a 40350000410 Stick on 1meter USB cable just 2 meters far from the first cover i try to pair.
The USB Key is successfuly mapped from my synology to home assistant, visible in material as :
DEVLINKS: >-
/dev/serial/by-id/usb-Becker-Antriebe_GmbH_CDC_RS232_v125_Centronic-if00
/dev/serial/by-path/pci-0000:00:04.0-usb-0:1:1.0
DEVNAME: /dev/ttyACM0
DEVPATH: /devices/pci0000:00/0000:00:04.0/usb2/2-1/2-1:1.0/tty/ttyACM0
I’ve integrated Becker cover support plus PyBecker with HACS successfully,
My configuration.yaml is :
cover:
- platform: becker
device: "/dev/serial/by-id/usb-Becker-Antriebe_GmbH_CDC_RS232_v125_Centronic-if00"
filename: "my-centronic-stick.db"
covers:
cuisine:
friendly_name: "Volet Cuisine"
channel: "1:1"
travelling_time_up: 13
travelling_time_down: 13
In logs i’ve got at startup :
2024-02-10 10:06:04.502 DEBUG (MainThread) [custom_components.becker.cover] device: /dev/serial/by-id/usb-Becker-Antriebe_GmbH_CDC_RS232_v125_Centronic-if00; filename: my-centronic-stick.db
2024-02-10 10:06:04.503 DEBUG (MainThread) [custom_components.becker.rf_device] Use filename: my-centronic-stick.db
2024-02-10 10:06:04.504 DEBUG (MainThread) [custom_components.becker.pybecker.becker_helper] Try to open connection.
2024-02-10 10:06:04.512 DEBUG (Thread-4) [custom_components.becker.pybecker.becker_helper] BeckerCommunicator thread started.
I put motors in Prog mod with the master contoller, i heard the “clac” once.
I call Service :
service: becker.pair
channel: 1
unit: 1
We can see in logs :
2024-02-10 10:06:47.029 DEBUG (Thread-4) [custom_components.becker.pybecker.becker_helper] Sent packet: unit_id: 1737B, channel: 1, command: TRAIN, argument: 1, packet: b’\x020000000002010B00B70000001737B021010100819C\x03’
2024-02-10 10:06:47.131 DEBUG (Thread-4) [custom_components.becker.pybecker.becker_helper] Sent packet: unit_id: 1737B, channel: 1, command: RELEASE, argument: 0, packet: b’\x020000000002010B00B80000001737B021010100001C\x03’
2024-02-10 10:06:47.238 DEBUG (Thread-4) [custom_components.becker.pybecker.becker_helper] Sent packet: unit_id: 1737B, channel: 1, command: TRAIN, argument: 1, packet: b’\x020000000002010B00B90000001737B021010100819A\x03’
But i dont have any “clac” confirmation from the stick pairing.
Does somebody see what’s wrong ?
