neildeadman
(Neil McKirdy-Deadman)
November 29, 2018, 4:20pm
1
I’m trying to add this https://github.com/rdehuyss/homeassistant-lovelace-google-calendar-card to my HA setup, but I get “Custom Element doesn’t exist: calendar-card”.
My configuration.yaml file is located at /opt/homeassistant/ which is where I created the ‘custom_components’ directory and added the custom_update.py file.
In my configuration.yaml I have:
custom_updater:
card_urls:
- https://raw.githubusercontent.com/rdehuyss/homeassistant-lovelace-google-calendar-card/master/custom_updater.json
I’m fairly new to HA but have managed to resolve my other issues, but this one has be stumped!
So I’ve not installed and configured the card, this is what you need to do.
First install and configure this, make sure its working on the none LoveLace-UI front end.
Then add the custom card to your www directory as below
/www/custom_ui/calendar-card/calendar-card.js
Then add the following lines to your ui-lovelace.yaml configuration
resources:
- url: https://unpkg.com/[email protected] /moment.js
type: js
- url: /local/custom_ui/calendar-card/calendar-card.js?v=1.0.1
type: module
- type: "custom:calendar-card"
showProgressBar: true
numberOfDays: 14
entities:
- calendar.noodlemctwoodle
- calendar.contacts
Further information can be found here
neildeadman
December 5, 2018, 10:52pm
4
Sorry for late reply, not had a chance to check my config until tonight. Having now done that, I already had all the bits you’ve said to add.
What I see is this:
Are you able to post your config?
Or you could check mine as I have it working
neildeadman
December 7, 2018, 11:09am
6
Thanks! You’ve got some good bits in your setup, which I have also used.
I cloned your github and put your www folder over mine and its now working. Maybe should have looked at it deeper, but its working which is the main thing!
neildeadman
December 7, 2018, 11:17am
7
Had a quick look and found my mistake! I was using
custom-ui
directory name instead of
custom_ui
Perfect, I’m glad you got it worked out and fixed
I’m sure there will be plenty more problems to fix. I update my repo almost daily now with changes to Lovelace
