Yes it is!
Awesome, thanks! I think I’ll have another go at integrating mine.
UPDATE:
The batteries of my Danalock died yesterday! So what I’ve said about the longevity of the batteries is WRONG! The reported battery state is completely false and can’t be trusted. See here a screenshot of the dead batteries:
these were in fact so empty, that it wouldn’t turn even slightly in any direction. And this appeared realtively sudden. I noticed that the Motor sounded a bit deeper for about a Week but because it stated it had 70% left i thought it’s normal. but no, it suddenly stopped working and even the danalock app (via bluetooth) reported middle battery percentage.
I could have been unlucky with my batteries, maybe they were bad, but the new ones I bought (for almost 30€! (but they are way cheaper on amazon)) are sowing around 80% already:
Is this a bug? Is my lock broken? Is it just a ZHA thing? I don’t know. (My lock is on SW 0.21.4)
Is it possible to pair Danalock zigbee with Sonoff ZB bridge?
I try to pair in eWeLink App, but there is no discovery of the lock.
Does anyone know, thanks a lot
Maybe the sonoff bridge is only for sonoff products?
Since I have updated the Dalalock v3 Zigbee software and the Zigbee firmware, I’ve experienced no more issues.
CR123 A Li-Ion Akku mit 3,7 Volt
Does it mean Danalock V3 handles 16.8V (4x4.2V, 4.2V is max V for fully charged Li-ion)?
There is to little info in the internet, but 3x16340 (CR123A sized Li-ion) should be enough?
Great news looks like Zigbee was fixed with new Update version 0.22.4, DanaLock v3 (zigbee) works for more than 24 hours and didn’t loose connection since then. I could not use the lock after updating from firmware 0.17.4.
Update: 7 days Still works good)
Nice to heare that you are satisfied with the lock. Is your door multilock since you mentioned sealing the door?
Hi peapole,
Can someone proved short guide how to integrate lock in HA?
Thank you in advance.
This is really short: set up a zigbee router and the respective home-assistant integration. Options are at least deconz, zigbee2mqtt, and ZHA. Then connect danalock to the zigbee network.
Which option works the best?
I bet zigbee2mqtt with some high quality coordinator like conbee.
I have it working on zigbee2mqtt with a slaesh zigbee stick. Very stable. For zigbee pairing, you first need to install the danalock software and start the pairing process from the software. There is some other way without the SW but I did not test this.
Also it should be noted, there is two firmwares. one for the lock (can only be updated from the danalock SW, and one for the zigbee part. This can be updated from zigbee2mqtt.
And regarding the setup in HA. You do not need a special integration. Z2M supports MQTT auto discovery, so as soon as they are paired the will show up automatically in HA (as MQTT devices).
Hi @nikler !
I would be super grateful if you could explain the procedure how you connected the Danlock v3 to Phoscon using Conbee. I have the same setup, but do not seem to be able to connect.
Did it long time ago but if I remember correctly you need to set up the lock in Danalock app first, just the basics, like calibrating lock/unlock.
Don’t try to pair using the “Smart home” button.
Set the lock in pairing mode using the button in the small hole, check the manual for number of presses.
In Home assistant, start deconz and then Phoscon, from there you add the lock as it were a light bulb (make sure the lock is still in pairing mode).
Hi again @nikler !
Thank you for sharing this with me. I managed to connect the lock to Phoscon as a light using the smart home zigbee option in the Danalock App. It actually integrates to HA as well, but the does not react when pressing the button.
Do you think i did something wrong?
Hi @EinzellerXD
would you mind explaining the pairing procedure of the Danalock v3 to HA via Deconz? I have a Conbee3 and paired the lock as a light using the zigbee option in smart home in the Danalock App… But though it integrates with Phoscon and HA it still refuses to work some how.
pressing the “unlock” option on the lock does not work.
Did you calibrate the lock in the Danalock mobile app first?
The lock needs to know the where the lock / unlock positions are.
You need to calibrate fist in app or with paper clip that trigger calibrate…
