I am writing to kindly request the creation of an integration for SpaNET (SpaLINK). SpaNET is a popular spa control system and many people would benefit from being able to integrate it with their Home Assistant setup.
I have come across a useful resource that could help with the development of this integration, which is the work done by BlaT2512 on Github at the following link: https://github.com/BlaT2512/spanet-api/blob/322214be7329b2a8517577d19744830dcd214210/spanet.md. This project provides an API for SpaNET, which could be a great starting point for creating an integration with Home Assistant.
I understand that creating integrations can be time-consuming and require a lot of effort, but I believe that having this integration would greatly benefit the Home Assistant community. I would be more than happy to help with testing and providing feedback during the development process.
Hai, I have been playing around with this a bit and given the smartlink can connect to Alexa I installed alexa media player and created a script to adjust the spa temperature for a test and it worked! I am 6 months in working with home assistant and have no background in this stuff (builder here) but pretty sure there would be a way to get temperature updates, turn on pumps, lights etc with the same method. A work around while an integration gets implemented I guess.
Here is the script I used;
alias: Test ALEXA
sequence:
service: media_player.play_media
media_content_id: alexa open MySpaPool and then set the temperature to 37’C
media_content_type: custom
entity_id: media_player.julian_s_echo_dot
mode: single
I’ve been playing around with this but can’t seem to get it to work. I’m a total newb so it’s probably something straightforward. Followed the directions in the readme, but get an error in the studio code server terminal inside home assistant. ChatGPT thinks I’ve misspelled something, but I’ve triple-checked.
➜ /config /bin/python /config/custom_components/sn2ha-main/sn2ha.py
File "/config/custom_components/sn2ha-main/sn2ha.py", line 43, in <module>
spaName = config.get("sn2ha","spaName")
File "/usr/lib/python3.11/configparser.py", line 797, in get
d = self._unify_values(section, vars)
File "/usr/lib/python3.11/configparser.py", line 1168, in _unify_values
raise NoSectionError(section) from None
configparser.NoSectionError: No section: 'sn2ha'
I use media player on HA to automate temperature changes when I am getting excess solar. That’s my only current work around while waiting for any update on this.
I also follow this Discord as the guys trying to implement it are pretty active on it
The python bridge is no longer being worked on, I abandoned this after realising how bad the Wifly based Spanet controller was. Instead I build my own ESP32 replacement controller (https://github.com/wayne-love/sn_esp32).
The code for the replacement controller is ugly but it works. I’m working on refactoring it but priority is low as it just works at the moment.
I’ve taken your fantastic code (it saved me a bunch of time) and turned it into an ESPHome climate external component. Using the simple-thermostat card, this is what I end up with:
Right hacked up your code, and then made a wrapper class for the ESPHome. C++ is not my first language, but it seems to work thus far. Will upload to github in the next few days for people to comment on how bad my code is
It’s worth noting for other readers - this is for an ESP connected to the spa - not for a factory SPA-Link device.
I did - my code is here. Put that in esphome > my_components > spanet. Provided with no warranty, your mileage may vary Works a treat for me though, enabled me to dynamically set my spa operating mode to make the most of free power times of the day (and solar).
Just as a FYI, the SpaNET support guys in Australia seem pretty good. They sold me a V3 (ESP32-based with MQTT support) for half price (AU$200 vs AU$400) and I sold my V2 on Facebook Marketplace for AU$150 so it only cost me AU$50 to upgrade.
I was a bit concerned that the V2 has a pretty solid antenna but the V3 uses the antenna printed on the circuit board, but it seems to be working with MQTT pretty well so far.
I followed this guy’s hardware guide for the hardware but used an ESP32 and mine wouldn’t work with the resistors in-line like he had them - but works fine without any resistors. Basically just an ESP, voltage reg (couple of bucks from ali) and an RJ45 cable.
