Integration for TP-Link Omada system
I didn’t try DNS name as I don’t have one normally. So I tried http://ip https://ip, https://ip/api/logon etc. Nothing works. Will try to set a DNS name
I also tried everything but not working. Switching on/off redirecting to HTTPS - but nothing change
Don’t think setting a DNS Name should be the solution. I would like to work with ip address also
There’s supposed to be an update coming out that will allow the ip to work as well, but until then, if you want to use the integration using a name instead of ip works. I agree it’s a bit silly to have to use the name, but bugs are bugs.
FWIW, currently only switches are pulled in from this integration (not APs or anything else) and only the poe for the ports. Nothing else. IMO, this is kind of a waste of an integration at the moment.
It is hard to be patient, but still this has more than the other integration that only had device trackers. Plus other support is planned so hopefully it can get to feature parity with the unifi integration and people can enjoy the same or similar functionality for a lot less money.
The router and AP device trackers of the HACS integration provide a lot of usefull information in the attributes.
My hope is that the new official integration will follow, but I don’t expect it for the near future.
source_type: router
ip: 10.0.0.2
mac: 1c:61:b4:XX:XX:XX
host_name: AP Büro
type: ap
model: EAP225-Outdoor(EU) v3.0
firmware: 5.0.8 Build 20220613 Rel. 51936
status: 14
status_category: 1
clients: 17
users: 17
memory: 56
upload: 7469739
tx_rate: 4207
rx_rate: 2033
icon: mdi:access-point-network
friendly_name: AP Büro
cpu: 1
source_type: router
ip: 10.0.0.1
host_name: ER605
type: gateway
model: ER605 v2.0
firmware: 2.1.2 Build 20230210 Rel.62992
status: 14
status_category: 1
icon: mdi:router-network
friendly_name: ER605
cpu: 15
memory: 33
upload: 8066007689
clients: 4
Allright, I wanted to try, but can’t get it to work. What is the exact URL to use?
I have set the controller to use omada.local as hostname, I can ping it, so I would think https://omada.local:443
You shouldn’t need the :443, but I don’t think it will hurt.
Honestly, I’m glad there are so many people that want to use an Omada integration. It took a long time to get this off the ground since I originally submitted it, but I did have plans to grow it a lot after getting the inital PR approved. The PR rules say you can only start with a single domain, so I chose switches for the PoE control, mainly because it’s what I actually needed first.
Sorry about the initial bugs - I have a DNS name for my controller, and I didn’t think to try with an IP address. :confused:
Fixes for these two things should be relatively easy. I’m not exactly sure how quick the HA release cycle is during the month, but hopefully you won’t have to wait too long. It looks like there are some other weird problems, but hopefully that will become clearer once all the noise dies down.
So. I do have lots planned, also willing to accept help :smiley: And, look at it this way, last week there was no integration, which isn’t a lot better than having a broken one…
Yeah I know, it was just to prevent questions about the configured port :wink:
if you need help on any topic (except developtment), i’m ready to do so. I tried the custom component before and was really eager to jump to this one instead.
Do i understand it wont work on config with just IP address?
I might have some documentation suggestions :slight_smile:
Try https://omada.local:8043 , it works for me
Thanks. It depends on your port setting I guess, for me it would be 443, but it’s not working.
Hopefully in the next update
very weird… in browser url, this work. Setting up the intragtion, it doesnt. There is no log at all, so i cant figure out which part is wrong.
@bagpuss did you have a peek at the custom component that already existed? ha-omada/config_flow.py at ed823c731af246bc6dd0286f6fb548d275321166 · zachcheatham/ha-omada · GitHub
that config flow worked for me, maybe cherry pick some setup there?
How can I find out my dns name?
Noob question: Will this integration allow us to control clients?
eg. I currently use Omada android app to allow or block internet access to my son’s tablet. Is there a roadmap to allow such functionality in this integration? If there is a way to do it, I can leverage home assistant automation on a whole lot of things.
For starters you should set it on your DNS server. After that in the interface, Settings, Controller > Access config
Anyway, it doesn’t work for me
Works fine for me to control POE on/off state
https://192.168.xxx.xxx
Verify SSL off
Or
https://your.omada.fqdn
Verify on, if you have a let’s encrypt cert.
With the new Home Assistant 2023.3.2 I noticed an update to the TP-Link integration.
I was hopefull about it, but unfortunately still not working.
The good thing is: there’s a different error message now: Invalid flow specified, coming from styles.ts:353
Works for me now https://ip-adress:8043. Verify SSL off. Running software controller 5.9.9.
Works for me as well, https://ip-address, verify SSL off. It does not yet recognize any devices other than the OC300 hardware controller I have and defaults to the only one site I have.
Am very excited to start testing as addiitonal functionality comes online. Below is the information about my current setup if needed. Which devices are going to next be supported? They should be all the below since I am more important than everyone else (ROFL)…
The Omada hardware I have is:
OC300 Hardware Controller
TL-ER7206 Router
TL-SG2218 Switch
EAP225 Ceiling WAP (two of these)
EAP225 Outdoor WAP
The router and switch are connected directly by CAT6
All three WAPs are connected with CAT6 directly to the switch
System Information
version core-2023.3.2
installation_type Home Assistant Supervised
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.10
os_name Linux
os_version 5.10.0-21-arm64
arch aarch64
timezone America/New_York
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 5000
Installed Version 1.31.0
Stage running
Available Repositories 1309
Downloaded Repositories 24
AccuWeather
can_reach_server ok
remaining_requests 17
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Debian GNU/Linux 11 (bullseye)
update_channel stable
supervisor_version supervisor-2023.03.1
agent_version 1.4.1
docker_version 23.0.1
disk_total 915.4 GB
disk_used 16.9 GB
healthy true
supported true
supervisor_api ok
version_api ok
installed_addons AppDaemon (0.11.0), Core DNS Override (0.1.1), Duck DNS (1.15.0), File editor (5.5.0), Home Assistant Google Drive Backup (0.110.1), Log Viewer (0.14.0), Mosquitto broker (6.1.3), Samba share (10.0.0), Terminal & SSH (9.6.1), AdGuard Home (4.8.2)
Dashboards
dashboards 5
resources 15
views 29
mode storage
Recorder
oldest_recorder_run February 7, 2023 at 1:58 AM
current_recorder_run March 8, 2023 at 4:39 PM
estimated_db_size 2256.60 MiB
database_engine sqlite
database_version 3.38.5
