There is a link to the api documentation in this thread. Omada SDN Controller API Document - Business Community (tp-link.com)
Just a quick FYIā¦Looks like Zach has been adding a lot of things lately:
Maybe you two could see about working together on this Omada integration.
got HA and Omada updated this week. As had initial issues with recorde on maria db i didnt notice omada integration broke.
2023-04-12 15:31:36.193 ERROR (MainThread) [homeassistant.components.switch] Error while setting up tplink_omada platform for switch
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 304, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/tplink_omada/switch.py", line 33, in async_setup_entry
network_switches = await omada_client.get_switches()
File "/usr/local/lib/python3.10/site-packages/tplink_omada_client/omadasiteclient.py", line 95, in get_switches
for d in await self.get_devices()
File "/usr/local/lib/python3.10/site-packages/tplink_omada_client/omadasiteclient.py", line 84, in get_devices
result = await self._api.request(
File "/usr/local/lib/python3.10/site-packages/tplink_omada_client/omadaapiconnection.py", line 145, in request
return await self._do_request(method, url, params=params, payload=payload)
File "/usr/local/lib/python3.10/site-packages/tplink_omada_client/omadaapiconnection.py", line 182, in _do_request
self._check_application_errors(content)
File "/usr/local/lib/python3.10/site-packages/tplink_omada_client/omadaapiconnection.py", line 203, in _check_application_errors
raise RequestFailed(response["errorCode"], response["msg"])
tplink_omada_client.exceptions.RequestFailed: Omada controller responded 'Operation forbidden.' (-1005)
guessing its the omada update as a lot changed in 5.9.31. The UI is starting from āglobalā and not default site.
so guessing a bit here, but not sure yet.
anyone seen this too?
Hello, I have 3 EAP225ās, an SG2218 (non-poe) switch ,an ER7205 and an OC300 (all Omada). Are you expecting to be able to add capabilities for those any time soon?
Yes, Iām aiming to add at least 1 feature a month, but I really only have time to work on this at quiet weekends. There is an open PR to add support for internet and LAN port connectivity status on gateways but itās fallen into a bit of a black hole waiting for review.
If someone wants to provide feedback⦠please do
There have also been quite a few changes happening in the underlying library which will form the basis of upcoming new features. A few helpful people have been providing very welcome contributions on the back-end.
Feature requests will be considered if you have anything you desperately want covered.
Thank you, totally understood it is volunteer and very deeply appreciated!
Feeling badly Iām unable to help so to rectify - just so you know where I am coming from, Iāve got an RPI 4b w/8Gig of Ram & 1tb SSD - so
Programmer in a past life mainly Windows - on Wall Street, low latency multi threaded realtime trading systems (C++, C#, Visual Sourcesafe, .NET, Visual Studio etc.). Moved into management (IT) and away from programming - but as programming is my first love careerwise, I picked up the above hardware and taught myself Linux & Python etc, networking expertise is pretty good but that is through a lot of time and effort and pain working on improving a customized home network.
So although the aptitude is there - I have no clue on how to even properly contribute and how GitHub works with regards to respectful contributions and vetting of code before check- in etc⦠So where is the best place to find some tutorials/samples for:
GitHub tutorial or paradigm/best practices for proper and tactful collaboration and polite way to contribute?
Tutorials/samples on how integrations work with HA and how to properly contribute - ?
FYI I do not have any dev environment or other RPI hardware so that is a consideration/hurdle -
Thanks for any guidance you can provide!
Yes, I have a specific request.
Would love to control client reconnect/block/unblock from within ha for automations. That would probably be a service for client entities based on mac.or up adress.
Not a small addition probably, but would love to assist testing/validating.
Yes, the WAN/LAN connectivity sensors went live in the 2023.06 release.
Iām going to look at adding more sensors next.
Ok, now i get the firmware implementation in this integration:
Never considered an install button here when you first delivered this, now I see
Any help needed on new features btw?
Thank you for all of this. So excited to see what comes next!
Maybe this is impossible, but I often goo into my Omada settings and turns trotting policies on and off. It would be great to have just a switch on a dashboard to flip some of those values!
I donāt mean to be rude but are any new features planned for this integration?
Yes @bagpuss you have us all excited! Whatās next?
I justed wanted to chime in because I searched for a way to enable/disable wi-fi of Omada access points using Homeassistant (e.g. bound to a HA switch).
Iāve successfully set up the Omada integration with the latest version of HA and a self-hosted Omada software controller (latest version, using the docker image) and two access points EAP615-Wall(EU) v1.0
. The two devices showed up as expected.
Iām glad to test with these devices if thatās helpful.
You can do this with the other (one of the other) integrations that I mention in this post: Integration for TP-Link Omada system - #63 by danbutter
I run both at the same time. I was hoping for the same kinda feature set as the unifi crowd has, but not quite there yet.
I have both the HACS version and the built in version of the Omada integration installed, and neither shows rx-rate or tx-rate, which was the whole reason i installed these⦠how did you get them in your attributes?
I can see the Rx and Tx Activity with the integration from hacs. Shows in MB/s.
I just went to the integration and selected a device.
ā¦totally wrong topic, sorryā¦
I have both integrations installed, but I also donāt see the Rx, Tx Activity on any of the integrations.
Go to Settings ā Devices & services ā Entities. Click on āSearch entitiesā and enter āTxā. You should see a list of all the Tx-related entities the Omada integration has created.
