Integration for TP-Link Omada system
I liked the GitHub - zachcheatham/ha-omada: Home Assistant TP-Link Omada Integration integration, The only problem is it adds all the devices as the device tracker.
Instead, If we get the clientList as JSON would be helpful so that we can show that in the UI. I tried forking it and getting the client JSON, but creating a sensor does not work as the sensor state cannot be more than 255 chars and my JSON goes above 10000 chars.
Any suggestion on how to store that big JSON somewhere, so that we can use it for templating or creating a table out of it?
Is this not available for the software controller yet? I have mine running in docker and it’s not connecting sadly.
On Unraid. Unless the firewall on the unraid is blocking the port
I use both of the Omada integrations (at the same time) and run my software controller in a VM on proxmox.
No issues here. Never used unraid so can’t help there, but it does work with the software controller.
migrated my controller over from unraid to proxmox and set up perfectly.
Must be an unraid thing
although very few entities on the integration
I use both integrations because they each have different thing they offer. Maybe try both to see if you could get more of what you are looking for.
I’m not sure why this post made it this far. WTHs asking for integrations is against one of the rules for WTH.
Unfortunately, I cannot move this to Feature Requests, I tried. The system does not let me. Therefore you’ll need to recreate the Feature Requests and continue voting there.
Sorry for the inconvenience.
I have the power :wink:
Noice, and it transferred the votes.
