I have a huawei supported device * Huawei 5G CPE Pro 2 (H122-373)
for huawei_lte integration. The problem is the integration fails with error:
Error: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:997)
This is because the huawei forces the dns to hirouter.net which has expired certitifcate 16 nov 2022, and huawei don’t seem to have sorted it out. I have tried forcing it to use the IP address with some dns hacks without success.
I read other users who had issues with self signed certs used the verify_ssl: false parameter
in configuration.yaml to bypass certificate verification
example
If I edit configuration.yaml as follows
huawei_lte
url: !secret url_lte # http://x.x.x.x/ (slash is required at the end)
username: !secret lte_user
password: !secret lte_pwd
verify_ssl: false
I get error:
Invalid config for [huawei_lte]: [verify_ssl] is an invalid option for [huawei_lte]. Check: huawei_lte->huawei_lte->0->verify_ssl.
Can anyone advise what I am doing wrong, or how to get this to work? Thanks
