I have verify_ssl set to “false” (Verify_ssl: false) for the Generic IP Camera, but it’s failing to get an image, with the
Error getting new camera image: Cannot connect to host xxx.xxx.xxx.xxx:443 ssl:None [[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:720)]
It looks like it’s still trying to verify the cert!
If I try setting Verify_ssl: true, then I get the exact same error message.
Camera: https://www.home-assistant.io/components/camera.generic/
ivanfor
(Ivan Forcada)
December 2, 2018, 2:13pm
2
Same here.
Has anybody managed to fix it?
Stewface
(Stewart)
March 15, 2019, 9:28pm
3
Richard.Huish:
This just started happening to me too, anyone figured out any solutions?
Nope, had to switch to unsafe http
elik745i
(El Nur)
September 24, 2021, 12:15pm
5
did you manage to add these cameras?
try the following:
Try to use the following, I have managed to add camera!
- platform: generic
stream_source: rtsp://login:[email protected] :554/onvif1
still_image_url: rtsp://login:[email protected] :554/onvif1
rtsp_transport: udp
authentication: digest
username: login
password: pass
verify_ssl: False
in the lovelace:
type: picture-elements
title: Door Bell 2 Camera
camera_image: camera.doorbell1
elements:
- type: state-icon
tap_action:
action: more-info
entity: camera.doorbell1
icon: mdi:arrow-expand-all
style:
top: 5%
right: 5%
color: white
opacity: 0.5
transform: ' scale (1.5, 1.5) '
camera_view: live
