Hello
I installed wlcrs/huawei_solar integration from HACS. But I can’t configure it because it says this
This is what you can see from the log.
2022-10-20 19:03:03.046 WARNING (MainThread) [pymodbus.client.asynchronous] Importing deprecated clients. Dependency Twisted is Installed
2022-10-20 19:03:03.070 ERROR (MainThread) [homeassistant.loader] Unexpected exception importing platform custom_components.huawei_solar.config_flow
File “/usr/src/homeassistant/homeassistant/loader.py”, line 722, in get_platform
cache[full_name] = self._import_platform(platform_name)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 739, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File “/usr/local/lib/python3.10/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 992, in _find_and_load_unlocked
File “”, line 241, in _call_with_frames_removed
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in call_with_frames_removed
File “/config/custom_components/huawei_solar/init.py”, line 18, in
from huawei_solar import HuaweiSolarBridge, HuaweiSolarException, InvalidCredentials
File “/usr/local/lib/python3.10/site-packages/huawei_solar/init.py”, line 6, in
from .bridge import HuaweiSolarBridge # noqa
File “/usr/local/lib/python3.10/site-packages/huawei_solar/bridge.py”, line 22, in
from huawei_solar.huawei_solar import AsyncHuaweiSolar, Result
File “/usr/local/lib/python3.10/site-packages/huawei_solar/huawei_solar.py”, line 14, in
from pymodbus.client.asynchronous.async_io import (
File “/usr/local/lib/python3.10/site-packages/pymodbus/client/asynchronous/async_io/init.py”, line 9, in
from pymodbus.client.asynchronous.mixins import AsyncModbusClientMixin
File “/usr/local/lib/python3.10/site-packages/pymodbus/client/asynchronous/mixins.py”, line 2, in
from pymodbus.client.sync import BaseModbusClient
File “/usr/local/lib/python3.10/site-packages/pymodbus/client/sync.py”, line 180, in
class ModbusTcpClient(BaseModbusClient):
File “/usr/local/lib/python3.10/site-packages/pymodbus/client/sync.py”, line 184, in ModbusTcpClient
def init(self, host=‘127.0.0.1’, port=Defaults.Port,
AttributeError: type object ‘Defaults’ has no attribute ‘Port’
2022-10-20 19:03:03.076 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading configuration flow for integration huawei_solar: Exception importing custom_components.huawei_solar.config
flow
Could you help me where the error could be?
