Any new updates?
Hi everyone,
I managed to get this running last night (bhyve-mqtt).
Building the docker image wasn’t too too bad, just had to figure out the .env file variables and repackage each time. May look into setting a volume with the file so that it can exist outside of the image.
After you clone the github repository, edit the /app/.env-sample file and add your details, then save it as .env in that same /app directory. For the MQTT_BROKER_ADDRESS value, if you’re running mqtt as a docker image, you should be able to refer to it as the container’s name. I’m running my mqtt as “mosquitto-mqtt”, so the MQTT_BROKER_ADDRESS=mqtt://mosquitto-mqtt. No port, the “mqtt://” at the beginning is required. Once all your info is in, go back the the root directory of the project and do a “docker build”. This will create the image for you to deploy. There are a tone of blogs out there with the steps to follow, but my docker-compose is very simple:
bhyve:
image:
depends_on:
- “mosquitto-mqtt”
I haven’t played around with commands yet, but I was at least able to see my device info in the container log.
Looking forward to playing around with this. Thanks!
Great news! We’re you able to get commands working yet?
Not quite yet, been focusing more on a video/NVR solution for us which was more pressing.
But hope to do some work on it soon! I’ll keep this thread posted.
Count me in as a tester!
I’m definately interested as well.
This is awesome. Would you be willing to share some of your sensor configurations?
Count me in as a tester as well, I’m using one to water my garden.
Would be epic to get info or turn the sprinklers on via HA.
Count me in for testing too
thanks for your hard work!
i tested, and as you , at least i see something in the mqtt server, i need to spend some more time to figure out next steps…
thank you
Looks promising, any more updates?
Hi, can we expect any progress here? My Irritation hardly needs some improvements which HA could provide.
Until someone figures out a way to integrate directly with the device itself, potentially through the Web interface or by the use of an API, we’re out of luck. Having to go through a middleware (ie. MQTT) is not a viable option for most people. However, it may be useful to help build knowledge around a scalable and “permanent” solution.
Thanks!
Ok, agree. We should open a request. Thanks
I have it running in docker mqtt is connected but I get this error, which I have seen many times in my setup but unable to fix.
2019-10-06T01:44:46.414Z - Orbit Error: Error: write EPROTO 140181838559040:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:../deps/openssl/openssl/ssl/s23_clnt.c:797:
Everything in google is relating to a proxy but I dont use one.
Any ideas?
Hey folks.
I have started building a b-hyve integration for hass. It currently exposes a sensor for battery levels and binary_sensor for rain delays, with some plans for switches to trigger watering commands.
If anyone wants to try it out or pitch in and contribute, repo can be found here:
https://github.com/sebr/bhyve-home-assistant
YMMV!
thanks! i’ll try today!
Thank you, it is already installed, the battery level sensor is shown as “unkown”… please continue with your project…
