Hi
Can anybody give me full manual how install Home Assistant on INTEL NUC ? And how i can create backup or backup as image SSD disk…
Intel NUC DN2820FYKH Will be ok for Home Assistant with 120GB SSD and 4GB RAM ?
Hi
I simply flashed the NUC image to the SSD with Etcher
But image hassio for NUC?
and @pepeEL i succeded by burning the image with etcher to my m2.ssd via a m2 usb dongle and now im in love with my NUC Bluetooth is working
Link to the guide i followed: Can't install Hass.io from USB on NUC?
Now i need install on SSD by USB Hass.io and then run it on rpi3+ or new rpi4. But Hassio not support boot from USB.
If you have a nuc you have to take out ssd and mount it in a USB adapter, and then via Etcher burn the image to the ssd like you do with the RPI
Anyone having issues with an error of:
IPv6: ADDRCONF(NETDEV_UP): wlp2s0: link is not ready
I have updated the BIOS on my NUC6CAYH and have burned the image of HASSIO NUC 2.12 onto my SSD. I have retried this several times, but I can never get past this error no matter how long I wait. The NUC is connected via ethernet and appears on my network. Any ideas?
Hi, Did you ever solve this ? in the same position.
So you’re getting the image with HassOS, Supervisor, and Core? Or are you installing on Debian/Ubuntu?
installed via:
With the Intel Nuc image. In the meantime got in the portal, only console is still showing
Now i know i can get in, does not bother me anymore if it is not an issue.
Personally, I used this (installed back in October or so), and have had great success.
Realize everyone has their own personal flavor / preference.
Yah, I use something similar to that but with debian.
what do you mean ‘console’? Do you have a monitor plugged into your nuc?
Anyways, if you have a monitor plugged it, it will never load and only show a console.
Correct it was when I connected the monitor. It looks like it is the wifi adapter which I do not use anyway. Working fine for now
