Does anyone happen to know if this equipment can be fully integrated with Home Assistant?
It’s claimed to be a TUYA ZigBee device, but I can’t find any information about it.
It claims TuYa, did you you try to talk to it with the Tuya smartlife app?
If that goes OK you have the TuYa core integration via the cloud or the Tuya Local (sorta) integrations from GitHub via HACS to pull it into HA.
Thanks for your response @Sir_Goodenough
Yes, I know very well that I can use the Tuya APP and there is more then a way to integrate the devices with HA.
I’m sorry I wasn’t clear in my request. This device is ZigBee and I would like to integrate it via ZHA or Zigbee2Mqtt as I don’t want to use the TuYa APP at all.
My biggest concern is whether the sensors will be created correctly when using ZHA
Any suggestion?
ZHA.
Look here to see if your device is supported or if someone has a quirk files to tide you over until it is supported assuming it is not.
If you are looking at how to use the quirks, How to setup local ZHA quirks.
Has a discussion about it.
Otherwise your fall=back as I mentioned is one of the HA TuYa integrations.
Did you ever get an answer to this?
