Interlogix Ultrasync
I don’t think it’s possible.
I use the Alarm panel integration, so maybe it’s possible if I can add this way. Maybe you can look at the Alarmo integration?
I don’t see anything usefull in the docs GitHub - nielsfaber/alarmo: Easy to use alarm system integration for Home Assistant. I don’t think it is possible through that plugin either :frowning:
Sorry I’m new to HA. How do I define a 4x2 grid?
Check the github: https://github.com/caronc/ha-ultrasync#lovelace-ui
The grid is the look of the card :wink:
I copied and pasted your code, however the button layout isn’t the same as yours. It’s a 4x4 square. I have the layout and button cards. what card do I use?
Euhm, weird. It should be copy paste and work…
Does this work:
type: custom:button-card
entity: sensor.ultrasync_area1state
show_name: false
show_state: true
show_label: false
styles:
  card:
    - height: 106px
state:
  - value: Ready
    color: green
    icon: mdi:shield-check
  - value: Not Ready
    color: green
  - value: Armed Stay
    color: orange
    icon: mdi:shield-account
  - value: Exit Delay 1
    color: orange
    icon: mdi:shield-lock
    styles:
      card:
        - animation: blink 2s ease infinite
  - value: Armed Away
    color: red
    icon: mdi:shield-home
  - value: Burglar Alarm
    color: red
    icon: mdi:shield-alert
    styles:
      card:
Hey guys, just letting you know I pushed a new version to HACS adding XGen v8 support (this should open the UltraSync support to even more people).
Thanks Caron! With NX-596 is not compatible, just configured the integration and get a “Failed to connect” error. Tried to follow the steps to make a debug dump, but I get the following error:
hassio@hassio:~/ultrasync$ bin/ultrasync -c /home/hassio/ultrasync/config --debug-dump
File "bin/ultrasync", line 56, in <module>
from ultrasync.cli import main
File "/home/hassio/ultrasync/ultrasync/__init__.py", line 34, in <module>
from .main import UltraSync
File "/home/hassio/ultrasync/ultrasync/main.py", line 40, in <module>
from .config import UltraSyncConfig
File "/home/hassio/ultrasync/ultrasync/config.py", line 27, in <module>
from urllib.parse import urlparse
ImportError: No module named parse
Apple Watch configuration, to turn Alarm On or Off
Paste this in your configuration.yaml file, if you have a separate automations to the automations.yaml file
Once you have done this, choose a watch face and change one of the complications to HomeAssistant
ios:
  actions:
    - name: Alarm Away
      background_color: "#00ff00"
      label:
        text: "Tune ON Alarm Panel"
        color: "#000000"
      icon:
        icon: shield_account
        color: "#ffffff"
    - name: Alarm Disarm
      background_color: "#ff0000"
      label:
        text: "Tune OFF Alarm Panel"
        color: "#ffffff"
      icon:
        color: "#ffffff"
automation:
  - alias: "Set Alarm in Away Mode"
    initial_state: true
      - platform: event
        event_type: ios.action_fired
        event_data:
          actionName: 'Alarm Away'
      - service: ultrasync.away
      - service: notify.mobile_app
          message: Alarm Panel
          title: Alarm Set in Away Mode by Apple Watch
  - alias: "Disarm Alarm"
    initial_state: true
      - platform: event
        event_data:
          actionName: 'Alarm Disarm'
      - service: ultrasync.disarm
          title: Alarm Disarmed by Apple Watch
I just got a Comnav unit (NX-595E) installed. Unfortunately, with the latest firmware, the web port is only accessible if the security system is in programming mode. I haven’t seen any way to disable that yet.
Great piece of integration; really impressed and I also very much would like to use this in my home environment :slight_smile: I tried to set it up today but noticed that the ATS Advanced 1500A-IP unit which I have uses a slightly different way to connect using ‘UltraSync’. it is not username/password based but with a 24-position encryption key (all numeric values) and the pin-code as also used on the controller device to (dis)arm. Connections run on port 32000 via the local IP.
Would it be possible to create an alternative login scenario to also support these kind of Ultrasync devices? I’m happy to test any scripts if needed, can do some python but not a brilliant coder :slight_smile:
The readme indicates it will work with NX-595E Hills ComNav, xGen, xGen8 (such as NXG-8-Z-BO), Interlogix, and ZeroWire UltraSync solutions.
Has this been confirmed to work with the Ultrasync Modular Hub (Interlogix UM-5000-CPU)?
All these different names can be confusing!
https://www.interlogix.com/intrusion/product/ultrasync-modular-hub
Hey @l2g! Thanks again for putting this integration together, to this day its a key part to some of my favorite automations. Just a heads up that I am seeing the below warnings in logs recently.
  • Entity sensor.ultrasync_zone17state (<class ‘custom_components.ultrasync.sensor.UltraSyncSensor’>) implements device_state_attributes. Please report it to the custom component author.
What would be the easiest way of creating binary_sensors from these created sensors so that they can be seen and used in Alarmo? Thanks in advance!
EDIT:
I ended up using this template, but if anyone has a better way, feel free to share!
binary_sensor:
    sensors:
      front_door:
        friendly_name: "Front Door"
        device_class: door
        value_template: "{{ 'off' if is_state('sensor.front_door', 'Ready') else 'on' }}"
I’m so excited that I stumbled on this page. I worked for interlogix until their US shutdown in 2018. I’d love to help this along as much as I can though it seems you’re doing very well so far without any internal help.
I have a plethora of old equipment if anyone needs something to test with etc
Just wanted to apologize to everyone as i have not been a very good maintainer of this code. Life has gotten very busy. So I welcome any Pull requests people have.
At this time i haven’t updated my Home Assistant in a while; so I’m not getting the warnings you guys are. It seems they’ve changed the underlining structure of Home Assistant and there are deprecation warnings coming to my plugin. I can’ promise that i have the time to fix this, but hopefully someone will tackle this.
There are 2 core pieces of this tool for those who want to contribute:
  1. The core: The full integration from any PC to access your Security Panel. This works without Home Assistant and can be re-used for integrations into other systems if you wanted to.
    • This is where you go to add new features/functions to the integration
  2. The Home Assistant integration: Leverages the core defined above). The only thing that resides here is the bare minimum to patch/stitch together HA with the Core:
    • This is where those deprecation warnings are coming from.
Hey everyone. Just a heads up I made a very simple change that was required for us to get the attributes back. As of the latest update on HACs my attributes are back to normal!
Hello Everyone,
First thanks for this great integration, I have been able to connect my nx8 easily into HA.
I have been migrating from Openhab to HomeAssistant quite successfully. Still, one feature I had before is access to the journal/log of the nx8. I have been using it to know which user was arming or desarming the alarm and get notification when someone else than me is disarming the alarm. Pretty useful I have to say.
Do you think there is a way to get access to such information ?
best regards
Jonathan
Hi @l2g ,
Thank you for the integration! really nice job.
What i cannot understand though (new to this stuff) is how you create a toggle for each entity, so that you can use the bypass service.
An example would be great!!!
Thank you in advance
John
The way you want to use it, isn’t supported.
The only you can do to with this integration is toggle the alarm on (both home and stay functions) or off.
You can also read the current state of a sensor (motion or no motion).
You can’t bypass any sensors with this integration.
