Introducing ... TheSillyHome , a Homeassistant Machine Learning (AI) Addon
Hi Team! Apologies for quite a delay in releasing new features. I was hit with the virus and wasn’t feeling all to well.
I have now pushed a new version to dev in dockerhub under the dev tag. This will be into the next weeks stable version.
This update includes changes to the frontend.
  1. Recalibration with a button (instead of restarting the container ) for zero downtime. The Console logging is not async and so does only show output once the re-running completes.
  2. Metrics dashboard - you can now review how the models are performing.
Keep it silly folks!
The next update is going to be focused on the models and accuracy :slight_smile: (the fun stuff)
thats nice ) i found that my new models was schooled by the automations ) now i have two automations )
Check out this new thread, home to all our release documentation!
Checkout our new Silly Home service on the cloud.
It’s free. Sign up now!
This is a culmination of 3 months of hard work and your interest, feedback and support is crucial to its development. Even if your platform is not available yet, sign up to register your interest!
No one here wants a cloud solution.
Hi, I installed and launched thesillyhome-addon-repo. What to do next? How to use it?
Hi! I installed the Addon in Home assistant. Configured
- db_password: password
  db_username: homeassistant
  db_host: 192.168.1.134
  db_port: "3306"
  db_database: home-assistant_v2.db
  db_type: sqlite
installed
MariaDB
Current version: 2.5.2
In the magazine writes:
Starting to parse DB data
2023-02-07 09:21:56,743 - root - INFO - Reading from homedb...
2023-02-07 09:21:56,754 - root - INFO - Getting data from internal homeassistant db
2023-02-07 09:21:56,754 - root - INFO - Executing query
2023-02-07 09:21:56,763 - root - WARNING - Cannot find actuator cases for ids {'light.bathroom_lights', 'switch.livingroom_entrance_switch_right', 'light.bedroom_ceiling_light', 'switch.livingroom_entrance_switch_left', 'light.bedroom_sidetable_lamp', 'light.corridor_lights', 'switch.livingroom_entrance_switch_center'}. Removing...
2023-02-07 09:21:56,763 - root - WARNING - Cannot find sensor cases for ids {'binary_sensor.bathroom_entrance_sensor_occupancy', 'binary_sensor.corridor_end_sensor_occupancy', 'sensor.corridor_end_sensor_illuminance_lux', 'binary_sensor.livingroom_desk_sensor_occupancy', 'weather.home', 'sensor.livingroom_desk_sensor_illuminance_lux', 'sensor.corridor_entrance_sensor_illuminance_lux', 'sensor.bedroom_entrance_sensor_illuminance_lux', 'binary_sensor.chris_phone_is_charging', 'binary_sensor.bedroom_entrance_sensor_occupancy', 'device_tracker.chris_phone', 'binary_sensor.corridor_entrance_sensor_occupancy', 'sensor.bathroom_entrance_sensor_illuminance_lux'}. Removing...
2023-02-07 09:21:56,764 - root - INFO - []
2023-02-07 09:21:56,766 - root - INFO - Add previous state...
2023-02-07 09:21:56,766 - root - INFO - Start parallelization processing...
2023-02-07 09:21:56,784 - root - WARNING - No metrics.
2023-02-07 09:21:56,785 - root - INFO - Completed!
2023-02-07 09:21:56,799 - root - INFO - Runnining cron with cadence 0 0 * * 0
Starting Appdaemon
Starting frontend on 0.0.0.0:2300
Listening on 0.0.0.0:2300
2023-02-07 06:21:57.675989 INFO AppDaemon: AppDaemon Version 4.2.1 starting
2023-02-07 06:21:57.676117 INFO AppDaemon: Python version is 3.9.16
2023-02-07 06:21:57.676201 INFO AppDaemon: Configuration read from: /thesillyhome_src/appdaemon/appdaemon.yaml
2023-02-07 06:21:57.676305 INFO AppDaemon: Added log: AppDaemon
2023-02-07 06:21:57.676380 INFO AppDaemon: Added log: Error
2023-02-07 06:21:57.676444 INFO AppDaemon: Added log: Access
2023-02-07 06:21:57.676520 INFO AppDaemon: Added log: Diag
2023-02-07 06:21:57.688343 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2023-02-07 06:21:57.825857 INFO HASS: HASS Plugin Initializing
2023-02-07 06:21:57.826516 INFO HASS: HASS Plugin initialization complete
2023-02-07 06:21:57.826805 INFO AppDaemon: HTTP is disabled
2023-02-07 06:21:57.833473 INFO HASS: Connected to Home Assistant 2023.2.2
2023-02-07 06:21:57.846275 INFO AppDaemon: App 'model_executor' added
2023-02-07 06:21:57.848495 INFO AppDaemon: Found 1 total apps
2023-02-07 06:21:57.849276 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2023-02-07 06:21:57.877802 INFO HASS: Evaluating startup conditions
2023-02-07 06:21:57.887557 INFO HASS: Startup condition met: hass state=RUNNING
2023-02-07 06:21:57.887868 INFO HASS: All startup conditions met
2023-02-07 06:21:57.903660 INFO AppDaemon: Got initial state from namespace default
2023-02-07 06:21:59.854620 INFO AppDaemon: Scheduler running in realtime
2023-02-07 06:21:59.856436 INFO AppDaemon: Adding /thesillyhome_src/appdaemon/apps to module import path
2023-02-07 06:21:59.857432 INFO AppDaemon: Loading App Module: /thesillyhome_src/appdaemon/apps/model_executor.py
2023-02-07 06:22:00.116386 INFO AppDaemon: Initializing app model_executor using class ModelExecutor from module model_executor
2023-02-07 06:22:00.140936 WARNING model_executor: ------------------------------------------------------------
2023-02-07 06:22:00.141764 WARNING model_executor: Unexpected error running initialize() for model_executor
2023-02-07 06:22:00.142593 WARNING model_executor: ------------------------------------------------------------
2023-02-07 06:22:00.144165 WARNING model_executor: Traceback (most recent call last):
  File "/opt/venv/lib/python3.9/site-packages/appdaemon/app_management.py", line 165, in initialize_app
    await utils.run_in_executor(self, init)
  File "/opt/venv/lib/python3.9/site-packages/appdaemon/utils.py", line 337, in run_in_executor
    response = future.result()
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
  File "/thesillyhome_src/appdaemon/apps/model_executor.py", line 27, in initialize
    self.init_db()
  File "/thesillyhome_src/appdaemon/apps/model_executor.py", line 51, in init_db
    db_rules_engine.loc[0] = 1
  File "/opt/venv/lib/python3.9/site-packages/pandas/core/indexing.py", line 716, in __setitem__
    iloc._setitem_with_indexer(indexer, value, self.name)
  File "/opt/venv/lib/python3.9/site-packages/pandas/core/indexing.py", line 1682, in _setitem_with_indexer
    self._setitem_with_indexer_missing(indexer, value)
  File "/opt/venv/lib/python3.9/site-packages/pandas/core/indexing.py", line 1982, in _setitem_with_indexer_missing
    raise ValueError("cannot set a frame with no defined columns")
ValueError: cannot set a frame with no defined columns
2023-02-07 06:22:00.146623 WARNING model_executor: ------------------------------------------------------------
2023-02-07 06:22:00.147353 INFO AppDaemon: App initialization complete
Is this how it should be? Does it work? Where can I track or watch something? Thanks for the help
Hi @Vex - Apologies for the slow reply. Once launched, it should start making predictions and execute actions on your behalf.
Hi @customstudioyandexru,
From what I can see, the default actuators and sensors are used in the config. This would most likely not match your own entity_ids of actuators and sensors you have in your home. You would change the config to match them :slight_smile:
Почему то не выводит список. Так и должно быть?
For some reason there are no devices
Maybe you need to replace sqlite with mariadb
Does is work with InfluxDB as well?
I don’t see it on the list, any plans to support it?
Hi, first of all, thank you for your work! I would just like to check if this project is still active?
