Invalid config for [automation]: required key not provided @ data['action']
Any idea why HA throws this error for the following configuration:
input_boolean:
  switch_enable:
input_datetime:
  enable_time:
    has_date: true
    has_time: true
automation:
    platform: state
    entity_id: input_boolean.switch_enable
    to: 'on'
    service: input_datetime.set_datetime
    entity_id: input_datetime.enable_time
      date: '2018-07-10'
      time: '05:00'
This config file is loaded as package from configuration.yaml:
homeassistant:
  packages:
    test: !include test.yaml
I’m sure it’s something basic, but I’m new to HA and still familiarise myself with YAML.
Thanks.
try putting the entity_id from your action under the data: section with the same indentation as the date and time
Same error. The entire error log is:
Invalid config for [automation]: required key not provided @ data[ā€˜action’]. Got None
required key not provided @ data[ā€˜trigger’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
I’ve never specified an automation, either before or after using packages, without
- alias: blah, blah, blah
I don’t know if alias is required, or the dash is required (to make it a list element.) I’d suggest either:
automation:
- trigger:
    platform: state
    to: 'on'
      date: '2018-07-10'
      time: '05:00'
or:
automation:
- alias: Set datetime
    platform: state
    to: 'on'
      date: '2018-07-10'
      time: '05:00'
yeah, i missed that. pretty sure they need an alias
Sorry, no luck. Both options give me the same error. But just out of curiosity, I pasted the code directly into configuration.yaml and it works. Is there anything specific required for automation defined in a package?
Ok, after more digging I found the problem… when I moved the code into a package, I left previous automation keyword in configuration.yaml. After removing it, everything started to work.
Thanks for help all.
Ah, ok. FWIW, here’s what I have in my configuration.yaml:
homeassistant:
  packages: !include_dir_named packages
automation: !include_dir_merge_list automations
script: !include_dir_merge_named scripts
This allows me to use both packages as well as ā€œnormalā€ automation and script files. Any file I put in <config>/packages will be interpreted as a package file, anything in <config>/automations can contain a list of automations, and anything in <config>/scripts can contain a set of named scripts.
!include_dir_merge_list was the solution, thanks pnbruckner.
