Hi there community!
I updated to 2025.12 and got 37 repairs because of the Deprecation of legacy template entities. So I followed the repair instructions for my modbus integration.
Now when i check the systax, I get the warnings:
Configuration warnings
Invalid config for 'sensor' at configuration.yaml, line 14: required key 'platform' not provided
Invalid config for 'binary_sensor' at configuration.yaml, line 13: required key 'platform' not provided
in my conifguration.yaml:
modbus: !include modbus.yaml
binary_sensor: !include binary_sensor.yaml
sensor: !include sensor.yaml
binary_sensor.yaml
template:
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_emergency_power_possible
name: E3DC Emergency Power possible
state: '{{ states(''sensor.e3dc_ems_state'')|int|bitwise_and(4) > 0 }}'
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_battery_loading_blocked
name: E3DC Battery loading blocked
state: '{{ states(''sensor.e3dc_ems_state'')|int|bitwise_and(1) > 0 }}'
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_battery_unloading_blocked
name: E3DC Battery unloading blocked
state: '{{ states(''sensor.e3dc_ems_state'')|int|bitwise_and(2) > 0 }}'
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_weather_based_loading
name: E3DC weather based loading limiter
state: '{{ states(''sensor.e3dc_ems_state'')|int|bitwise_and(8) > 0 }}'
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_power_limiter
name: E3DC power limiter
state: '{{ states(''sensor.e3dc_ems_state'')|int|bitwise_and(16) > 0 }}'
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_smartcharge_unloading_blocked
name: E3DC SmartCharge unloading blocked
state: '{{ states(''sensor.e3dc_ems_state'')|int|bitwise_and(64) > 0 }}'
- binary_sensor:
- binary_sensor:
- default_entity_id: binary_sensor.e3dc_emergency_power_active
name: E3DC Emergency Power Mode Active
state: '{{ is_state(''sensor.e3dc_emergency_power_state'', ''1'') }}'
- binary_sensor:
- device_class: POWER
default_entity_id: binary_sensor.e3dc_emergency_power_available
name: E3DC Emergency Power Available
state: '{{ is_state(''sensor.e3dc_emergency_power_state'', ''1'') or is_state(''sensor.e3dc_emergency_power_state'',''2'') }}'
sensor.yaml
template:
- sensor:
- unit_of_measurement: '%'
default_entity_id: sensor.e3dc_autarky
state: '{{ (states(''sensor.e3dc_autarkie_eigenverbrauch'')|int / 256)|round(0,''floor'')}}'
- sensor:
default_entity_id: sensor.e3dc_own_consumption
name: E3DC Own Consumption ratio
state: '{{ ((states(''sensor.e3dc_autarkie_eigenverbrauch'')|int / 256 - states(''sensor.e3dc_autarky'')|int) * 256)|round(0,''floor'') }}'
# Grid out
- sensor:
- unit_of_measurement: W
device_class: POWER
default_entity_id: sensor.e3dc_netz_leistung_out
state: "{% if states('sensor.e3dc_netz_leistung') | int > 0 %}\n 0\n{% else -%}\n \ {{ (states('sensor.e3dc_netz_leistung') | int) | abs }} \n{% endif %}"
# Grid in
- sensor:
device_class: POWER
default_entity_id: sensor.e3dc_netz_leistung_in
state: "{% if states('sensor.e3dc_netz_leistung') | int > 0 %}\n {{ states('sensor.e3dc_netz_leistung') | int }}\n{% else -%}\n 0\n{% endif %}"
# Battery out
- sensor:
device_class: POWER
default_entity_id: sensor.e3dc_batterie_leistung_out
state: "{% if states('sensor.e3dc_batterie_leistung') | int > 0 %}\n 0\n{% else -%}\n {{ (states('sensor.e3dc_batterie_leistung') | int) | abs }} \n{% endif %}"
- sensor:
device_class: POWER
default_entity_id: sensor.e3dc_batterie_leistung_in
state: "{% if states('sensor.e3dc_batterie_leistung') | int > 0 %}\n {{ states('sensor.e3dc_batterie_leistung') | int }}\n{% else -%}\n 0\n{% endif %}"
- platform: integration
source: sensor.e3dc_batterie_leistung_out
unit_prefix: k
round: 2
source: sensor.e3dc_batterie_leistung_in
unit_prefix: k
round: 2
source: sensor.e3dc_pv_leistung
unit_prefix: k
round: 2
source: sensor.e3dc_string_1_power
unit_prefix: k
round: 2
source: sensor.e3dc_string_2_power
unit_prefix: k
round: 2
source: sensor.e3dc_powermeter_1_L1
unit_prefix: k
round: 2
source: sensor.e3dc_powermeter_1_L2
unit_prefix: k
round: 2
source: sensor.e3dc_hausverbrauch
unit_prefix: k
round: 2
source: sensor.e3dc_netz_leistung_in
unit_prefix: k
round: 2
source: sensor.e3dc_netz_leistung_out
unit_prefix: k
round: 2
I am not so familiar with the yaml syntax. What do I get wrong here?
Thx 4 any assistance
TLDR: Legacy template entities (alarm_control_panel, binary_sensor, cover, fan, light, lock, sensor, switch, vacuum, weather) are being deprecated in 2025.12. Legacy template entities will no longer work after 2026.6. I wanted to avoid the deprecation, however it’s apparent that it’s not possible due to future plans.
Do not use AI to migrate. AI will screw up the yaml. Use the tools provided in this post, if you use AI you are on your own.
The Deprecation
Please use this thread to ask ques…
You cannot just paste entities configured under the template integration into files like sensor.yaml and binary_sensor.yaml which are most likely included under the sensor and binary_sensor integrations respectively. They should be placed into configuration.yaml or a file properly split to be under the template integration.
I dont’t want to blow up my configuration.yaml but have it in seperate files. I thought, thats what includes are for. How do I manage this correctly?
Can you show an example?
At this point there are multiple examples in the deprecation notice thread linked above. If none of those show how to do it the way you want, see the link above about properly splitting your config…
Oh dear. I am new to this and absolutely no expert. I’m glad it worked with the old config syntax. I could really need some help…
but ok: from what I understand is I should do the following:
configuration.yaml
template: !include template.yaml
template.yaml
template:
- binary_sensor:
- binary_sensor:
<all the sensors>
<including all entries from binary_sensors.yaml>
Is that correct???
egehlhaar:
Is that correct???
Except the part where you say “including all entries from binary_sensors.yaml”… if you had binary_sensor entities that were not using platform: template, those need to stay where they were.
ok. getting there…
you see the contents of binary_sensor.yaml above. Means the entries
unit_prefix: k
round: 2
should stay in the binary_sensor.yaml?
Yes, the deprecation is only for the template platforms.
mcarty
(Arturo)
December 4, 2025, 5:51pm
9
Add this line to your configuration.yaml:
template: !include ./yaml/templates.yaml
And then paste your repair code there
For instance templates.yaml would be like
- binary_sensor:
- name: **************
- state: *********
egehlhaar
(Eike)
December 4, 2025, 10:01pm
10
I’ve done that. But I recieve a check error:
Invalid config for 'template' at template.yaml, line 1: 'template' is an invalid option for 'template', check: template
but as far as I understood from you guys, it looks fine…
template.yaml
# from binary_sensor.yaml
template:
- binary_sensor:
- binary_sensor:
- binary_sensor:
- binary_sensor:
- binary_sensor:
- binary_sensor:
- binary_sensor:
- binary_sensor:
- binary_sensor:
# from sensor.yaml
- sensor:
- sensor:
# Grid out
- sensor:
device_class: POWER
# Grid in
- sensor:
device_class: POWER
# Battery out
- sensor:
device_class: POWER
- sensor:
device_class: POWER
whats wrong?
Remove the template: from the top of the file. That is not needed when using that inclusion method.
Technically, you can also remove most of the domain keys too…
template.yaml:
- binary_sensor:
# from sensor.yaml
- sensor:
# Grid out
device_class: POWER
# Grid in
device_class: POWER
# Battery out
device_class: POWER
device_class: POWER
egehlhaar
(Eike)
December 4, 2025, 10:06pm
12
ok, that did the trick. Thanks so much for your help. Appreciate it!
I have hundreds of template sensors and binary sensors. If only these helpful new configs could be automatically put in a template file along with an include line in the config file and the old sensors commented out. Its going to take ages to go through all these one by one.
That would never have been allowed by the core devs…
Never.
Home assistant does not change your yaml. Ever.
Even if a YAML integration is imported into the GUI it is still up to you to delete the old config.
This is a good thing.
This does not preclude someone making a third party tool to do it though I guess.
The contemporary syntax for sensors and binary sensors was introduced over 4 years ago… and you still have 6 months until the old syntax stops working…
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
December 7, 2025, 12:05am
16
This change actually happened like more than a year ago, and you have 6 more months to fix it…
rouxdoo
December 7, 2025, 4:43am
17
This change was no biggie to me. The repair warning included the correct YAML that was needed. I copy/pasted into my config.yaml file and commented out the old ones and it was all good.
Least stressful breaking change ever!
