Invalid config The following integrations and platforms could not be set up: automation
So just restarted HA and I am getting the following error
Logger: homeassistant.config
Source: config.py:416
First occurred: 15:22:25 (7 occurrences)
Last logged: 15:34:25
Invalid config for [automation]: not a valid value for dictionary value @ data['action'][3]['entity_id']. Got None. (See /config/configuration.yaml, line 240).
line 240 of configuration.yaml is
### INCLUDE ##
group: !include groups.yaml
I am up to date Home Assistant 2021.2.3
supervisor-2021.02.11
I have not made any changes to my Automations or configuratio.yaml so do not understand what is going on?
Is it an error with the configuration.yaml or one of my automations as the log is unclear?
The 4th action of one of your automations is missing an entity_id for a service call.
Thanks Tom, that was it I had made a change to one pf my camera entities
was
camera.back_garden
I changed it in error to
camera.back_garden-substream
Should have been
camera.back_garden_substream
How did you get to that conclusion from this?
The part “See /config/configuration.yaml” confused me?
Regards,
This says there is something wrong with an automation:
This says there is something wrong with the data in the 4th action (the index starts counting at 0, so [3] is the 4th one.
And this says what’s wrong, a missing entity_id:
The line numbers can be misleading if you have split your config.
A post was split to a new topic: Help with Pyscript Error
