slipx06
(Slipx06)
January 27, 2026, 9:09am
634
Everything looks good. Please paste your full card config, preformatted like the example below. Also make sure the entity is load_frequency_192
entities:
use_timer_248: switch.sunsynk_toggle_system_timer
priority_load_243: switch.sunsynk_toggle_priority_load
day_battery_charge_70: sensor.sunsynk_day_battery_charge
day_battery_discharge_71: sensor.sunsynk_day_battery_discharge
day_load_energy_84: sensor.sunsynk_day_load_energy
day_grid_import_76: sensor.sunsynk_day_grid_import
day_grid_export_77: none
day_pv_energy_108: sensor.sunsynk_day_pv_energy
inverter_voltage_154: sensor.sunsynk_inverter_voltage
load_frequency_192: sensor.sunsynk_load_frequency
inverter_current_164: sensor.sunsynk_inverter_current
inverter_power_175: sensor.sunsynk_inverter_power
ja500001
(Jon)
January 27, 2026, 10:48am
635
thanks @slipx06 , here is my card
cardstyle: full
wide: true
large_font: false
show_solar: true
show_battery: true
show_grid: true
center_no_grid: false
card_height: 100%
card_width: 100%
decimal_places: 1
decimal_places_energy: 1
dynamic_line_width: true
max_line_width: 4
min_line_width: 1
inverter:
modern: false
colour: "#9e9e9e"
autarky: power
model: sunsynk
auto_scale: true
three_phase: false
navigate: ""
label_autarky: ""
label_ratio: ""
battery:
show_daily: true
invert_power: false
show_remaining_energy: true
remaining_energy_to_shutdown: false
invert_flow: true
energy: 30000
count: 1
soc_decimal_places: 1
max_power: 30000
auto_scale: false
soc_end_of_charge: 100
shutdown_soc: 10
dynamic_colour: true
navigate: https://blasta.eu.solar-assistant.io/
battery2:
energy: 0
shutdown_soc: 20
invert_power: false
hide_soc: false
colour: "#ffc0cb"
show_absolute: false
auto_scale: true
linear_gradient: true
animate: true
path_threshold: 100
navigate: ""
invert_flow: false
solar:
show_daily: true
mppts: 1
load:
show_daily: true
auto_scale: false
dynamic_icon: true
show_aux: false
additional_loads: 0
grid:
show_daily_buy: true
show_daily_sell: true
show_nonessential: true
grid_name: Octopus
invert_flow: false
auto_scale: true
energy_cost_decimals: 1
additional_loads: 0
type: custom:sunsynk-power-flow-card
entities:
use_timer_248: switch.not_connected_use_timer
priority_load_243: sensor.not_connected_load_power_essential
inverter_voltage_154: sensor.not_connected_ac_output_voltage
inverter_current_164: sensor.not_connected_battery_current
inverter_power_175: sensor.not_connected_battery_power
grid_load_freq_192: sensor.deye_sunsynk_sol_ark_ac_output_frequency
grid_connected_status_194: sensor.not_connected_grid_energy_out_compensation
day_battery_charge_70: sensor.not_connected_battery_energy_in
day_battery_discharge_71: sensor.not_connected_battery_energy_out
battery_voltage_183: sensor.not_connected_battery_voltage
grid_power_169: sensor.not_connected_grid_power_ct
day_grid_import_76: sensor.not_connected_grid_energy_in
day_grid_export_77: sensor.not_connected_grid_energy_out
grid_ct_power_172: sensor.not_connected_grid_power_ct
essential_power: sensor.not_connected_load_power_essential
nonessential_power: sensor.not_connected_load_power
day_pv_energy_108: sensor.gc150146_0_energy_today
pv1_power_186: sensor.solar_panels_current_power
energy_cost_buy: sensor.octopus_energy_electricity_22j0552939_1800030000010_current_rate
grid_voltage: sensor.not_connected_grid_voltage
energy_cost_sell: >-
sensor.octopus_energy_electricity_22j0552939_1800061472306_export_current_rate
prog1_time: select.not_connected_time_point_1
battery_current_191: sensor.not_connected_battery_current
battery_current_direction: sensor.not_connected_battery_current
battery_temp_182: sensor.not_connected_battery_temperature
battery_power_190: sensor.not_connected_battery_power
prog2_time: select.not_connected_time_point_2
prog3_time: select.not_connected_time_point_3
prog4_time: select.not_connected_time_point_4
prog5_time: select.not_connected_time_point_5
prog6_time: select.not_connected_time_point_6
battery_soc_184: sensor.deye_sunsynk_sol_ark_battery_state_of_charge
battery_status: number.not_connected_battery_absorption_charge_voltage
prog6_charge: switch.not_connected_grid_charge_point_6
prog5_charge: switch.not_connected_grid_charge_point_5
prog4_charge: switch.not_connected_grid_charge_point_4
prog3_charge: switch.not_connected_grid_charge_point_3
prog2_charge: switch.not_connected_grid_charge_point_2
prog1_charge: switch.not_connected_grid_charge_point_1
prog1_capacity: number.not_connected_capacity_point_1
prog2_capacity: number.not_connected_capacity_point_2
prog3_capacity: number.not_connected_capacity_point_3
prog4_capacity: number.not_connected_capacity_point_4
prog5_capacity: number.not_connected_capacity_point_5
prog6_capacity: number.not_connected_capacity_point_6
aux_connected_status: select.not_connected_generator_connected_to_grid_input
essential_load1: sensor.not_connected_load_power
day_load_energy_84: sensor.not_connected_load_energy
grid_ct_power_total: sensor.not_connected_grid_power
non_essential_load1: sensor.not_connected_load_power_non_essential
title: Energy Flow
title_size: 16px
grid_options:
columns: full
rows: 8
I am not sure why there are so many sensors listed as “sensor.not_connected_xxx”, their values are still be displayed on the card itself though …
slipx06
(Slipx06)
January 27, 2026, 11:11am
636
@ja500001 This sensor is wrong grid_load_freq_192: sensor.deye_sunsynk_sol_ark_ac_output_frequency . Change it to load_frequency_192: sensor.deye_sunsynk_sol_ark_ac_output_frequency
ja500001
(Jon)
January 27, 2026, 11:34am
637
Yes, that’s fixed it, thank you so much for spending the time to help me on this, absolute GOAT!
antonical
(Tony)
February 28, 2026, 10:00pm
638
HI Thank you for all your hard work in producing this power flow card.
Is it possible to support multiple sunsynk inverters and batteries on one power flow card. If so how?
Setup will shortly be:
Inverter 1 G98 Sunsynk Acure with 32kWh battery CT on a sub circuit.
Inverter 2 G99 Sunsynk Inverter with 64kWh battery. The building will be on the load port with the primary CT on the grid port. G98 will be downstream of the load port on one of the sub circuits.
Is there a way to config the power flow card to show this type of setup. Essentially the G98 Inverter is AC Coupled the only ‘grid’ it sees is the grid peresented by the upstream Inverter 2. Inverter 2 has the main incoming grid feed connected to its grid port. CT on its live incomer and zero export across both inverters.
Any help figuring this out is appreciated.
Just posting the current config and card in case it helps others. The modbus data comes from a WaveShare RS485 to ETH (B) POE adaptor wired into the RS485/CAN port using a splitter. The Battery uses the CAN and the WaveShare uses the RS485. Seems rock solid in terms of data.
# Sunsynk Acure 3.6
- name: "sunsynk_direct"
type: tcp
host: 192.168.0.131
port: 8899
# delay: 5 # Increased: 5s delay after connecting to let the bus settle
# timeout: 10 # Increased: Give the picky 3.6 unit 10s to reply
# message_wait_milliseconds: 250 # Gap between messages to prevent "Extra Data" errors
# retries: 3
switches:
- name: "direct_modbus_toggle_system_timer"
slave: 1
address: 248
write_type: holding
command_on: 255
command_off: 0
verify:
address: 248
input_type: holding
state_on: 255
state_off: 0
- name: "direct_modbus_toggle_priority_load"
slave: 1
address: 243
write_type: holding
command_on: 1
command_off: 0
verify:
address: 243
input_type: holding
- name: "direct_modbus_grid_charge_1"
unique_id: "sunsynk_chg_slot_1"
slave: 1
address: 274
command_on: 1
command_off: 0
verify:
address: 274
input_type: holding
state_on: 1
state_off: 0
sensors:
- name: "direct_modbus_inverter_voltage"
slave: 1
address: 154
scale: 0.1
precision: 1
unit_of_measurement: "V"
device_class: voltage
- name: "direct_modbus_load_frequency"
slave: 1
address: 192
scale: 0.01
precision: 2
unit_of_measurement: "Hz"
device_class: frequency
- name: "direct_modbus_inverter_current"
slave: 1
address: 164
scale: 0.01
precision: 2
unit_of_measurement: "A"
device_class: current
- name: "direct_modbus_inverter_power"
slave: 1
address: 175
unit_of_measurement: "W"
device_class: power
- name: "direct_modbus_grid_acrelay_status"
slave: 1
address: 194
- name: "direct_modbus_runstatus"
slave: 1
address: 59
- name: "direct_modbus_battery_etoday_charge"
slave: 1
address: 70
scale: 0.1
precision: 2
unit_of_measurement: "kWh"
device_class: energy
state_class: total_increasing
- name: "direct_modbus_battery_etoday_discharge"
slave: 1
address: 71
scale: 0.1
precision: 2
- name: "direct_modbus_grid_power"
slave: 1
address: 169
device_class: power
- name: "direct_modbus_grid_etoday_from"
slave: 1
address: 76
scale: 0.1
precision: 2
- name: "direct_modbus_grid_etoday_to"
slave: 1
address: 77
scale: 0.1
precision: 2
- name: "direct_modbus_grid_power_ct"
slave: 1
address: 172
device_class: power
- name: "direct_modbus_load_daily_used"
slave: 1
address: 84
scale: 0.1
precision: 2
- name: "direct_modbus_aux_power"
slave: 1
address: 166
device_class: power
- name: "direct_modbus_pv_mppt0_power"
slave: 1
address: 186
device_class: power
- name: "direct_modbus_pv_mppt1_po```wer"
slave: 1
address: 187
device_class: power
- name: "direct_modbus_pv_mppt0_voltage"
slave: 1
address: 109
scale: 0.1
precision: 1
- name: "direct_modbus_pv_mppt0_current"
slave: 1
address: 110
scale: 0.1
precision: 1
- name: "direct_modbus_pv_mppt1_voltage"
slave: 1
address: 111
scale: 0.1
precision: 1
- name: "direct_modbus_pv_mppt1_current"
slave: 1
address: 112
scale: 0.1
precision: 1
- name: "direct_modbus_pv_etoday"
slave: 1
address: 108```
input_type: holding
scale: 0.1
precision: 2
- name: "direct_modbus_grid_voltage"
slave: 1
address: 150
scale: 0.1
precision: 1
- name: "direct_modbus_battery_soc"
slave: 1
address: 184
unit_of_measurement: "%"
data_type: uint16
device_class: battery
- name: "direct_modbus_battery_voltage"
slave: 1
address: 183
input_type: holding
scale: 0.01
precision: 2
- name: "direct_modbus_battery_temperature"
slave: 1
address: 182
input_type: holding
unit_of_measurement: "°C"
scale: 0.1
offset: -100.0
precision: 1
device_class: temperature
- name: "direct_modbus_battery_current"
slave: 1
address: 191
scale: -0.01 # Added minus to flip the sign
precision: 2
data_type: int16
- name: "direct_modbus_battery_power"
slave: 1
address: 190
input_type: holding
scale: -1 # Added scale to flip the sign
data_type: int16
device_class: power
- name: "direct_modbus_battery_direction"
slave: 1
address: 189
input_type: holding
- name: "direct_modbus_battery_soc1_cap"
slave: 1
address: 268
input_type: holding
scan_interval: 30
template:
- number:
- name: "Sunsynk Battery Limit"
state: "{{ states('sensor.direct_modbus_battery_soc1_cap') | int(20) }}"
step: 1
min: 0
max: 100
set_value:
- action: modbus.write_register
hub: sunsynk_direct
slave: 1
address: 268
value: ["{{ value | int }}"]
Maybe it’s possible to have 2 instances of the Power Flow Card
running talking to different inverters and batteries.
Cheers
Nice, I’ve been looking for an all-in one card that supports both energy and power instead of just focusing on one metric at a time, while also supporting loads and such.
llaforest
(Laurence Laforest)
March 13, 2026, 10:05am
641
Hi, I’ve been using this card with a Luxpower 12k inverter in a whole-house backup configuration (grid + generator + solar + battery). During grid outages the backup generator takes over, but the card has no way to represent generator as an AC input source — it currently only supports generator as an AUX output.
I opened a GitHub feature request for this: Backup generator as grid-replacement power source · Issue #808 · slipx06/sunsynk-power-flow-card · GitHub
The idea is to allow choosing the AC source displayed in the grid branch — grid (default, no change), generator (for off-grid systems), or auto (swap between grid and generator based on a status entity). Would love to hear if others have a similar setup and would find this useful.
Roman-F-EF
(Roman F Ef)
April 3, 2026, 12:22pm
642
“Deye sagt” ist die jeweilige Darstellung der gelesenen Register. Es entfällt somit eine vorherige Abfrage der eingestellten Werte.
Roman-F-EF
(Roman F Ef)
April 3, 2026, 12:25pm
643
System mit 3 Wechselrichtern.
I was wanting to ask is there a way to work this with 2 inverters with out having to combined them all into one?
nkair19
(Courtney)
May 7, 2026, 2:54pm
645
I can't seem to figure out why the grid sell back flow is going to non essential load rather than to grid. I don't even have non essential loads configured:
cardstyle: full
wide: true
large_font: true
show_solar: true
show_battery: true
show_grid: true
card_height: 100%
card_width: 100%
decimal_places: 2
max_line_width: 4
min_line_width: 1
inverter:
modern: true
colour: "#9e9e9e"
autarky: "no"
model: lux
auto_scale: true
three_phase: false
navigate: ""
label_autarky: ""
label_ratio: ""
battery:
energy: sensor.battery_bank_50200e0116_battery_bank_power
show_daily: true
count: 1
shutdown_soc: sensor.flexboss21_50200e0116_state_of_charge
auto_scale: true
invert_power: true
show_remaining_energy: false
show_absolute: true
hide_soc: true
battery2:
energy: 0
shutdown_soc: 20
invert_power: false
hide_soc: false
colour: "#ffc0cb"
auto_scale: true
animate: true
path_threshold: 100
navigate: ""
invert_flow: false
solar:
show_daily: true
mppts: 3
colour: "#e40707"
display_mode: 1
dynamic_colour: false
load:
show_daily: false
show_aux: false
aux_dynamic_colour: true
show_daily_aux: true
auto_scale: true
additional_loads: 2
load1_name: Lightning
load2_name: Pool
load1_icon: mdi:ev-plug-ccs2
load2_icon: mdi:pool
dynamic_icon: true
load1_switch: sensor.grid_boss_5074850700_smart_load_1_power
load2_switch: sensor.grid_boss_5074850700_smart_load_2_power
grid:
auto_scale: true
invert_grid: true
grid_name: Duke Energy
invert_flow: false
load2_icon: ""
disconnected_icon: ""
show_absolute: true
energy_cost_decimals: 0.19
export_colour: "#0dd924"
entities:
day_battery_charge_70: sensor.flexboss21_50200e0116_charging
day_battery_discharge_71: sensor.flexboss21_50200e0116_discharging
day_grid_export_77: sensor.flexboss21_50200e0116_grid_export
day_pv_energy_108: sensor.flexboss21_50200e0116_yield
pv1_power_186: sensor.flexboss21_50200e0116_pv1_power
pv2_power_187: sensor.flexboss21_50200e0116_pv2_power
pv3_power_188: sensor.flexboss21_50200e0116_pv3_power
battery_soc_184: sensor.flexboss21_50200e0116_state_of_charge
day_load_energy_84: sensor.flexboss_load_energy_today
essential_load1: sensor.grid_boss_5074850700_smart_load_1_power
essential_load2: sensor.grid_boss_5074850700_smart_load_2_power
pv_total: sensor.flexboss21_50200e0116_pv_total_power
battery_power_190: sensor.flexboss21_50200e0116_battery_power
battery_status: sensor.flexboss21_50200e0116_battery_status
battery_current_191: sensor.battery_bank_50200e0116_battery_bank_current
battery_voltage_183: sensor.flexboss21_50200e0116_battery_voltage
inverter_power_175: sensor.flexboss21_50200e0116_ac_power
grid_power_169: sensor.flexboss21_50200e0116_grid_power
day_grid_import_76: sensor.flexboss21_50200e0116_grid_import
grid_ct_power_172: sensor.flexboss21_50200e0116_grid_power
view_layout:
position: main
title: Geffert Energy
grid_options:
columns: full
Hi everyone!
I have been investigating why animated power flows
are not working on iPad and found the root cause.
The Problem
Animated dots/flows NOT working on iPad in ALL browsers:
Home Assistant App
Safari
Chrome
Works perfectly on iPhone in all browsers
Key Discoveries
During HA restart, animation works on iPad
for a few seconds, then stops after full load.
When enabling "Request Mobile Website" in Safari
on iPad → animation WORKS (but layout becomes squished).
This confirms iPad receives LEGACY build (with ShadyCSS)
instead of MODERN build like iPhone.
ShadyCSS does not support dynamic CSS → animation breaks.
Environment
HA Version: 2026.4.2
Bug exists since: HA 2024.8.0
Card Version: latest
Fix needed
HA serves legacy build to iPad but modern build to iPhone.
Card developer needs to use static CSS styles (classMap/styleMap)
instead of dynamic styles.
Has anyone found a working solution?
Small update:
On iPadOS the card renders correctly and all values update normally, but the animated power flows do not move at all.
Tested in:
Home Assistant Companion App
Safari
Chrome
The same dashboard works correctly on Mac and iPhone.
iPad settings checked:
Low Power Mode off
Reduce Motion off
Frontend cache reset
Could you please suggest any CSS workaround for iPadOS/WebKit, or confirm whether this is a known limitation?
I can test any card_mod CSS snippet if needed.
Thank you.
wgumaa
(Waleed)
May 20, 2026, 5:04pm
648
@Dmytro0118
I am using an old iPad with iPadOS 17.7.11 & the latest companion app. Have you tried through a browser on the iPad?
For me the animation works.
Yes, I tested it in both the Companion App and browsers (Safari and Chrome) on the iPad — same behavior everywhere.
I’m on iPadOS 26.5, so it’s not due to an outdated version.
It seems like an iPadOS/WebKit issue with SVG animations — the data updates correctly, but the flow animation freezes.
On iPhone and desktop everything works fine.
Could you check if the flow animation is actually moving on your device, or if only the values are updating?
schau mal über deine frage. da sind 3 wechselrichter im system
