Add optional dynamic speed animations depending on power draw. PR#29. Thanks @Papsnoek. New attributes can be configured for battery, grid, load and solar. If not defined this is disabled and default speeds are used.
animation_speed: - Set slowest animation speed in seconds, depending on Power draw
max_power: - Maximum Power draw to calculate animation speed
Adds an optional attribute (invert_grid:) to invert grid power. See Readme.
These are the registers I read for the 8KW. You can look at my Github (WIKI) as each sensor has the register referenced in its name. Please share you ESPHome config
OK try these grid_external_power_172: sun12k-Out-of-grid–total power inverter_load_grid_169: sun12k_Total_Grid_Power inverter_out_164: sun12k_Grid_Current_L1+sun12k_Grid_Current_L2+sun12k_Grid_Current_L3 (you need to create a template sensor to sum these 3) essential_power: sun12k_Load_totalpower
You need to get the full entity ID for those sensors from the Developer tools. I just pulled those names from your ESPHome config. Just filter on the state names and then use the full entity ID shown.
LIke I said you need to create a template sensor that add those three sensors for inverter_out_164. Search the forums on how to do this
sensor.sun12k_Grid_Current_L1+sensor.sun12k_Grid_Current_L2+sensor.sun12k_Grid_Current_L3 / 3
so you do the /3 to divide the sum and get the total current…
hi…
I add this line to my YAML file and the save and hit install get this error !!!
1./
INFO ESPHome 2023.5.5
INFO Reading configuration /config/esphome/deye12k.yaml…
ERROR Error while reading config: Invalid YAML syntax:
while scanning a block scalar
in “/config/esphome/deye12k.yaml”, line 1037, column 13:
lambda: |-return sensor.sun12k_Grid_Curr …
expected chomping or indentation indicators, but found ‘r’
in “/config/esphome/deye12k.yaml”, line 1037, column 15:
lambda: |-return sensor.sun12k_Grid_Curren …
@slipx06 can make or create second set of autarky/ratio against power values or make it option to use either energy or power values to calculate autarky/ratio
as you see below the first graph is using live power values
SORRY i made a fault at the keyboard !!! but your code did the work, it was my big fat finger there made the error, so now it is working…now I just have to fix the last (red ring)
v1.6.0 Updates
This release adds System Timer information to the battery display. (PR#36 Thanks @Papsnoek). The card accepts 18 (optional) additional sensors to read data for the six time slots (prog1 - prog6). For example prog1 sensors below:
|prog1_time:| Optional | select.ss_prog1_time | Program 1 start time (HH:MM)
|prog1_capacity:| Optional | number.ss_prog1_capacity | Program 1 capacity (SOC) setting
|prog1_charge:| Optional | select.ss_prog1_charge | Program 1 charge options (on/off, 0/1, No Grid or Gen)
The battery display will show the set time slot SOC capacity next to the current SOC and adjust the time to charge or discharge accordingly. There is an additional icon next to the Timer On /Timer Off text which indicates if grid charge is active/inactive for the current time slot.
The Auxiliary load can be renamed using the optional aux_name: attribute under the Load section
The Non-essential load can be configured to display two additional sensor values i.e. Geyser/Car charger and supports renaming. The following new optional attributes have been added to the Grid Section:
nonessential_name: Set the display name for the Non-Essential Load
nonessential_dual: Toggle the display of two Non-Essential loads (yes/no)
load1_name: Set the display name for the Non-Essential Load 1
load2_name: Set the display name for the Non-Essential Load 2
The following entity sensors will be read to populate the two loads:
non_essential_load1: Sensor that contains the power of your non-essential load (W)
non_essential_load2: Sensor that contains the power of your non-essential load (W)
