It’s documented here
https://slipx06.github.io/sunsynk-power-flow-card/index.html
Exciting New Features
- feat: battery information can be hidden from the card with
show_battery: false
- chore: added translations for da, de, es, et, fr, nl, ru,
Full Changelog: v2.4.1…v2.5.0
Patches & Bug Fixes
- fix: display additional essential loads correctly when
show_solar: false
and/orshow_battery: false
Full Changelog: v2.5.0…v2.5.1
v2.6.0
- feat: adds an optional card title. Set size and colour.
- chore: update README and de translation
Full Changelog: v2.5.1…v2.6.0
title: Sunsynk Inverter
title_colour: Grey
title_size: 32px
Beautiful card, thank you very much for your work.
If anyone needs 10K for Goodwe, I have the code for the card.
type: custom:sunsynk-power-flow-card
cardstyle: lite
panel_mode: false
large_font: false
title: GOODWE
title_colour: '#fffacd'
title_size: 28px
show_solar: true
show_battery: true
inverter:
modern: true
colour: '#fffacd'
autarky: power
battery:
energy: 10650
shutdown_soc: 20
colour: '#00ff00'
show_daily: true
full_capacity: 100
empty_capacity: 20
solar:
colour: '#ffd700'
show_daily: true
mppts: 2
animation_speed: 9
max_power: 8000
pv1_name: ZÁPAD
pv2_name: JIH
pv3_name: East
pv4_name: West
load:
colour: '#00bfff'
show_daily: true
show_daily_aux: true
show_aux: true
invert_aux: false
aux_name: Generator
aux_type: gen
aux_colour: green
aux_off_colour: red
aux_loads: 2
aux_load1_name: Aux load 1
aux_load2_name: Aux load 2
aux_load1_icon: mdi:air-filter
aux_load2_icon: mdi:stove
animation_speed: 8
max_power: 8000
additional_loads: 2
load1_name: BOJLER
load2_name: KLIMATIZACE
load1_icon: mdi:water-boiler
load2_icon: mdi:air-conditioner
grid:
colour: '#00bfff'
show_daily_buy: true
show_daily_sell: true
no_grid_colour: '#a40013'
show_nonessential: true
invert_grid: true
nonessential_name: Non Essential
nonessential_icon: oven
additional_loads: 2
load1_name: Load 1
load2_name: Load 2
load1_icon: boiler
load2_icon: mdi:dishwasher
animation_speed: 8
max_power: 8000
entities:
use_timer_248: none
priority_load_243: input_boolean.nabit_baterii_ze_site
day_battery_charge_70: sensor.today_battery_charge
day_battery_discharge_71: sensor.today_battery_discharge
day_load_energy_84: sensor.today_load
day_grid_import_76: sensor.fve_nakup_daily
day_grid_export_77: sensor.fve_prodej_daily
day_pv_energy_108: sensor.today_s_pv_generation
day_aux_energy: sensor.sunsynk_day_aux_energy
inverter_voltage_154: sensor.napeti_stridac
load_frequency_192: sensor.meter_frequency
inverter_current_164: sensor.ampery_stridac
inverter_power_175: sensor.sunsynk_inverter_power
grid_power_169: sensor.house_consumption
pv1_power_186: sensor.pv1_power
pv2_power_187: sensor.pv2_power
pv3_power_188: none
pv4_power_189: none
pv_total: sensor.pv_power
pv1_voltage_109: sensor.pv1_voltage
pv1_current_110: sensor.pv1_current
pv2_voltage_111: sensor.pv2_voltage
pv2_current_112: sensor.pv2_current
pv3_voltage_113: none
pv3_current_114: none
pv4_voltage_115: none
pv4_current_116: none
battery_voltage_183: sensor.battery_voltage
battery_soc_184: sensor.battery_state_of_charge
battery_power_190: sensor.battery_power
battery_current_191: sensor.battery_current
essential_power: none
essential_load1: sensor.load_l3
essential_load2: sensor.back_up_l2_power
nonessential_power: none
non_essential_load1: sensor.nonessential1_power
non_essential_load2: sensor.nonessential2_power
grid_ct_power_172: sensor.active_power
grid_connected_status_194: sensor.grid_mode_code
inverter_status_59: sensor.on_grid_mode_code
aux_power_166: sensor.sunsynk_aux_power
aux_connected_status: binary_sensor.sunsynk_aux_connected_status
remaining_solar: sensor.pv_power
battery_temp_182: sensor.battery_temperature
radiator_temp_91: sensor.inverter_temperature_radiator
dc_transformer_temp_90: sensor.inverter_temperature_air
prog1_time: sensor.sunsynk_time_slot_1
prog1_capacity: number.sunsynk_system_mode_soc_time1
prog1_charge: switch.sunsynk_system_mode_grid_charge_time1
prog2_time: sensor.sunsynk_time_slot_2
prog2_capacity: number.sunsynk_system_mode_soc_time2
prog2_charge: switch.sunsynk_system_mode_grid_charge_time2
prog3_time: sensor.sunsynk_time_slot_3
prog3_capacity: number.sunsynk_system_mode_soc_time3
prog3_charge: switch.sunsynk_system_mode_grid_charge_time3
prog4_time: sensor.sunsynk_time_slot_4
prog4_capacity: number.sunsynk_system_mode_soc_time4
prog4_charge: switch.sunsynk_system_mode_grid_charge_time4
prog5_time: sensor.sunsynk_time_slot_5
prog5_capacity: number.sunsynk_system_mode_soc_time5
prog5_charge: switch.sunsynk_system_mode_grid_charge_time5
prog6_time: sensor.sunsynk_time_slot_6
prog6_capacity: number.sunsynk_system_mode_soc_time6
prog6_charge: switch.sunsynk_system_mode_grid_charge_time6
energy_cost_buy: sensor.current_spot_electricity_price
energy_cost_sell: sensor.current_spot_electricity_price
solar_sell_247: sensor.on_grid_mode
In the sunsync-power-flow-card.js file, rename the .js extension to .txt and rename it to the native language in the note block. When you’re done, rename the .txt extension back to .js and copy it back to home assistant.
Integration must be manual!!!
If you have integration from hacs, renaming will not work!! I don’t know why.
Hi. The card does support translation of those text items if you set your HA language. I’ve created a few translations but none of them have been tested properly.
v2.7.0
- feat: adds optional auto scaling of power values for each of the card sections i.e. battery, solar, grid , load and inverter. When
auto_scale: true
power values greater than 999W will be displayed as kW i.e. 4,32kW. The number of decimal places is set to2
by default but can be adjusted globally using the carddecimal_places:
attribute
Full Changelog: Comparing v2.6.1...v2.7.0 · slipx06/sunsynk-power-flow-card · GitHub
thanks for the great work.
One question, is it possible to visualize a second inverter?
BG
Basti
Hi. Not at this stage.
Hello, could you please add a temperature function to aux load 1 and 2?
Marked on the photo
Thank you very much for your time and answer.
Can look at that. There is also a request for daily energy for the additional loads. Please add a feature request on GitHub, you can add to the existing one and I’ll see how best to implement
v2.8.0
- feat: you can now display extra sensor data for your additional essential loads e.g. daily energy or temperature etc. The following optional entities can be used:
essential_load1_extra
andessential_load2_extra
. This data is not displayed on the full card ifshow_aux: true
due to insufficient space.
Full Changelog: Comparing v2.7.2…v2.8.0
v2.9.0
I tried CZ language but still EN. If I change language to fr, de,… Translation is working. But Czech language still english. Restart and logout doesn’t work. Regards
Please, how to set the Czech language to be displayed?
I have version 2.9.1 manual integration and the program is displayed in English language. I updated the source for the card to /local/sunsync-power-flow-card/sunsync-power-flow-card.js?ver=2.9.1 so that the old card is not loaded from the cache and the English language is displayed.
My manual translation works flawlessly.
Yes, I tried the installation from HACS and the panel is set to the Czech language. Restart HA.
Unfortunately it doesn’t work. The advice is displayed in English language.
If I give my own translation, it works without a problem.
