IOS Mobile Notification not directing to custom dashboard
Here is the version that I’m working with:
I am also connected through home assistant cloud, which means that the URL to my dashboards look like this: https://hass.tagmdlhome.com/front-gate-doorbell-ring/0 (modified for privacy)
I have created a specific dashboard for this notification allowing me to see the camera and giving me the remove unlock button for the door.
When I look at the documentation for the syntax of an actionable notification here Actionable Notifications | Home Assistant Companion Docs (home-assistant.io), I see quotes around all of the URI values:
I’m able to include the quotes around all of the value and test.
When I click RUN
  • The notification shows up on my phone and on my Apple Watch.
  • On my phone I don’t see the ‘View Camera and Unlock’ title, on my watch I do. When I click the ‘View Camera and Unlock’ on my watch - I’m NOT taken to the dashboard that I have specific - I am given the listing of automations.
  • On my iPhone - I don’t ever see the ‘View Camera and Unlock’ title to click and when I click on the notification, it takes me to the default dashboard I have set on my iPhone.
When I save the automation and come back in, Home Assistant has removed all of the quotes from the entry data entry:
When I ‘run’ it without the quotes,
  • I still receive the notification and on my Apple Watch I see the ‘View Camera and Unlock’ message but I’m still not properly routed to the correct dashboard.
  • On my iPhone I also receive the notification, without the ‘View Camera and Unlock’ and it still takes me to the default dashboard set on the Home Assistant mobile app.
My Questions are:
  1. Is there a different uri value I should be using when connected through home assistant cloud?
I have tried including the /lovelace/front-gate-doorbell-ring/0 that all of the video tutorials and documentation specified with no success
I have tried using the full url https://hass.tagmdlhome.com/front-gate-doorbell-ring/0 with no success
  1. Why would the documentation show quotes around all three of the values but Home Assistant remove them when I save my automation?
Any ideas? This is going to be so powerful when I get this resolved!
did you ever get this resolved? I’m building some notifications that should direct to custom dashboards, but right now no matter what I use for URI values, the iOS mobile app simply opens whatever the last open dashboard was.
I continue to have the same issue. I haven’t been able to divert time back to the problem to figure out a workaround.
Curious, was this ever resolved? Running into same issue and not sure where to begin
It hasn’t and I haven’t really spent much time trying to figure it out. I am planning to circle back around now in the new year and see if I can get this to work because it will be brilliant if it worked as advertised!
Having this exact same issue. It was working and now suddenly it’s not!
Strangely I think I managed to get this working by removing ‘lovelace’ from all my links…
removing it from the dashboard you are trying to show on the iphone? So, if I create a new dashboard that isn’t a lovelace dashboard it should do the trick?
Try just putting in /front-gate-doorbell-ring/0 - I didn’t have to create any new Dashboards
