On the new version - somehow my device id got messed up…
on the app’s settings it still have chris_iphone_x
which is correct but now in HA, it shows it as:
I still have the old entity but it’s not updating:
Use the new one, you will get a new ID every time you set the app up again. So if you were to reinstall the app it will give you a new ID.
The old one will no longer work.
I hear ya but that doesn’t really say why versions (36, 37, 38 and 39) were fine and it just suddenly changed.
It is because RobbieT converted everything to a new component. Whereas the old versions still worked with the ios component. The app now uses mobile_app component instead of the old ios one.
Don’t ask why he converted all, but to my knowledge this is more secure and this way he doesn’t need to update the ios component individually. He can just update the app as it relies on mobile_app (which in turn can be used by other apps as well).
oh yeah, I remember reading that. I guess since we can’t edit the device trackers id, we wont be able to tie it in with icloud3.
It seems it broke ios messages, i will look into that.
Ios notifications? Or actionable notifications? They both should work. Just open the actionable ones in the app (the new way) you don’t need to do anything else just land on the page once. They should work again.
If you are talking about standard notifications, the ios component will be phased out as far as I know and it will use the new mobile_app component.
Open dev-tools and go to services. Find the following service: notify.mobile_app_PHONENAMEHERE, this will be the new way of notifying. Works fine here.
Yea I read about the mobile_app… It just doesn’t work.
I have had this mobile_app id from version 38 i think…
Output from node red after “successful” message even though I dont get it on device.
"_msgid":"c34949be.64a6c8",
"topic":"",
"payload":{
"domain":"notify",
"service":"mobile_app_chris_iphone",
"data":{
"title":"Home Status",
"message":"Performing Good Night",
"data":{
"push":{
"thread-id":"Home Actions",
"sound":"US-EN-Morgan-Freeman-Good-Night.wav"
it’s all very odd… I’ve restarted HA and node-red multiple times… that is the only mobile_app entry available…
Hm, I have to admit that I have reset the app/HA configs etc. After installing version 40.
It gave me completely new device tracker ID’s. But the same mobile_app ID’s. Did you try with dev-tools to send a message (meaning take node red out of the equasion). If it works it is maybe a node red problem (though I have never touched node red so I can’t comment on that).
Restart the app, reinstall it, restart HA several times with the app open etc. It might help, or might not at all. More people have these problems though so I am guessing that Robbie is working on it.
Yeah it’s so weird…
I tried on dev, hit Call Service and it did nothing… checked the console:
Internal server error, please try again later: That is not a valid FCM token
lol… i will wait until next version
Ensure that you see a push ID (a long string) in the app’s Notification Settings. Force restart the app once or twice until you do. Once you do, hit the up arrow in the web view to update the token to your HA. Things will start working then.
i have done that a few times too
So do you have a push ID showing in the app?
I do also have this new deviceID in my Setup after installing the beta.
Thank you for making this possible. I do like the upcoming features like Siri control and stuff.
I do also run die legacy app as well so I got nearly two identical devices tracked with two non equal IDs.
Is there anything else that comes with the beta app, which is not contributed on the Legacy App?
Do you think it will interference the current setup, when having legacy and beta app installed?
Im new into the world off HA, so don’t be so harsh with me
…if I did not found this topic I would still guess I messed up the deviceID of my iPhone myself.
Thank you in advance and enjoy your day.
(…starting off right here)
This is what I have…
iOS app:
iOS ID:
HA:
Does it get it’s name from the iPhone itself and not the device id?
That name still doesnt get any messages…
EDIT:
this is the error from sending the nofity command:
Just another FYI…
I did manage to fix this… On the intergrations screen I had 3 Entries for mobile_app_chris_iphone…
I deleted all 3. Restarted HA… opened iOS app, and did a reset… Closed and opened the app 2 more times and redid all my info. after i signed into HA on iOS app, i forced a location update and then I restarted HA again. After that, all was well.
So I just installed version 2.0 from the apple store. Congrats on the accomplishment. I’m trying to figure out what I need to do now as none of my automations work anymore. I now have two of each phone device. One has nothing in it and the other has a bunch of walking and other entities. Both devices based on the name of the phone.
Also am I supposed to remove known_devices.yaml?
We have created a migration guide for people in your exact position: https://companion.home-assistant.io/en/getting_started/migration
This should answer your questions about how to get back to your previous setup. From there you can start enhancing to use the new features. Enjoy!
Nice, thank you very much.
thanks for the update and the new features. Unfortunately it causes a lot of frustration to see V2.00 breaking a lot of things that have been working before. I had 3 iOS devices fully working with device trackers and notifications and after the update nothing works anymore. I just saw today the migration documentation. This should have been a message in the app.
The new names for the sensors are unlogical and make no sense at all. In Automation you now never know what device or person a sensor belongs to.
After the update Notifications are not available anymore for 2 of the 3 devices I have and for the only one working the name is notify.notify without any Device ID. Could it be that this is a bug and all 3 Devices got the same ID? There must be something wrong. Where can I see the notification settings? Its not listed in Mobile App integrations.
I´m still struggling to get everything working again. Don’t get me wrong I really appreciate the hard work on the app, but if you used it a while you would not expect the new versions breaks so many stuff and causes editing a lot of automations.
This was unavoidable unfortunately. The old trackers could not be migrated as the underlying platform of the old trackers is supposed to get removed from home assistant at some point.
The notify backend was replaced, once again that means new service endpoints.
Once all your devices are fully registered (three notify.mobile_app_XYZ services exist) you can actually use something like notepad++ to search and replace in all files and subdirectories and it should only take a minute to complete the migration. Then cleanup the old stuff. If you’re absolutely ocd, rename everything back to the old names then…
