IP Camera Snapshot Automation
I am trying to get a snapshot from an IP Camera when motion is detected on a separate motion sensor.
I have setup an automation that sends me a pushbullet notification when motion is detected but i wish to attach an image to this.
I have tried the snapshot functionality but the file wont save into the tmp file I have created. I have white listed the folder:
homeassistant:
  whitelist_external_dirs:
    -/tmp`Preformatted text
The automation for the snapshot is:
- action:
  - data:
      entity_id: camera.name
      filename: /tmp/snapshot.jpg
    service: camera.snapshot
  alias: SnapShot
  condition: []
  - entity_id: sensor.room_motion
    platform: state
    to: active
I do have a URL for my IP camera that grabs a still image, is this a better way?
Can anyone please help me understand what I am doing wrong?
I do have the same automation.
I think you’re missing the " in the path, but not sure if is so important.
Here’s my script:
  presence_kitchen_notifications_when_detected:
    alias: "Occupancy Detection - kitchen - Notifications"
    sequence:
    - condition: state
      entity_id: input_boolean.presence_kitchen_notify
      state: 'on'
    - service: camera.snapshot
        entity_id: camera.kitchen
        filename: "/config/www/cam_captures/kitchen_{{ now ().year }}_{{ now ().month }}_{{ now ().day }}_{{ now ().hour }}_{{ now ().minute }}.jpg"
    - delay:
        seconds: 5
    - service: notify.telegramChat_dave
        title: "Presence Detected at kitchen"
        message: "1.- presence_kitchen_notifications_when_detected - Occupancy Detection - kitchen - Notifications"
          photo:
            - file: "/config/www/cam_captures/kitchen_{{ now ().year }}_{{ now ().month }}_{{ now ().day }}_{{ now ().hour }}_{{ now ().minute }}.jpg"
              capture: Snapshoot
Hope this helps!
Thanks!
This enabled the snapshot to save to the correct folder. I am now having issues sending this file on pushbullet.
My automation is:
- action:
  - delay: '2'
  - alias: ''
      filename: /config/tmp/snapshot.jpg
      message: motion detected
    service: notify.home_assistant_alert
  alias: Motion Camera
  condition: []
  - entity_id: sensor.name_motion
    platform: state
    to: active
I am getting this error:
2018-01-30 10:14:21 ERROR (MainThread) [homeassistant.core] Invalid service data for notify.home_assistant_alert: extra keys not allowed @ data[ā€˜filename’]. Got ā€˜/config/tmp/snapshot.jpg’
I have tried with ā€œfileā€ rather than ā€œfilenameā€ with the same error.
Any ideas?
In my case I use telegram and based on the docs i needed yo use this way:
      photo:
          capture: Snapshoot
Please chechk if you have the data & photo tags for pushbullet …
only thing I can think of :slight_smile:
Thanks again got it working like this:
- action:
  - alias: ''
      title: Test
        file: /config/tmp/snapshot.jpg
  condition: []
    platform: state
    to: active
Great!! So what was the issue? (just out of curiosity :slight_smile: )
I needed to split out the message and file, so it went from:
to
  title: Test
Don’t supposed you’ve tried this with Pushbullet? I’ve used your template (thank you!) and have the notify set up like this:
  - service: notify.pushbullet
     title: Doorbell Pushed
     message: Photo from front door attached
      file: /config/www/cam_captures/porch_{{ now ().year }}{{ now ().month }}{{ now ().day }}-{{ now ().hour }}{{ now ().minute }}.jpg
Trouble is, Pushbullet is not finding the file that gets created returning the following error:
FileNotFoundError: [Errno 2] No such file or directory: '/config/www/cam_captures/porch_{{ now ().year }}{{ now ().month }}{{ now ().day }}-{{ now ().hour }}{{ now ().minute }}.jpg'
The file is there and called porch_2018327-1246.jpg but the template code is obviously wrong as it is looking for the template code itself rather than the correct file name.
Any suggestions would be appreciated.
P.S If I create a static image like this, it works fine:
        title: test
        message: test
          file: /config/www/cam_captures/camera.jpg
hey,
so I had the same issue and ended up that the Snapshot took longer than expected so I included a little delay on sending the photo.
- delay:
    seconds: 5
      photo:
          capture: Snapshoot
Also, for me it didn’t work without adding the filename with the ".
let me know if it works.
Did you ever get this to work? i’m experiencing the same issue with Pushbullet.
Nope. I just grab a single image now as Synology NAS is recording all video anyway so building a snapshot database inside Hass not really necessary.
- id: ID8
  alias: 'Pool Gate Open'
      platform: state
      entity_id: binary_sensor.door_window_sensor_158d00019fac86
      to: 'on'
    - service: tts.google_say
      entity_id:
        - media_player.kitchen_home
        - media_player.gaming_room_home
      data_template:
        message: "The pool gate just opened"
          entity_id: camera.pool_deck
          filename: '/config/www/images/pool_gate.jpg'
            file: '/config/www/images/pool_gate.jpg'
          title: "Pool Gate was opened"
          message: "Image of pool gate attached"
I struggled mightily with this, too. Turns out this is what works for my notify.smtp setup. Your mileage may vary:
- service: notify.gmail
    message: Gameroom door was opened
    title: We've been attacked
      html: <h4>Check the gameroom</h4>
      images:
      - /config/www/snapshots/new/gameroom.jpg
indent preformatted text by 4 spaces
I had already made a node-red flow using json that worked. I would never have figured out the yaml with a converter. JSON to YAML converter
I’ve done a script + automation, with ffmpeg, which creates a small video from the CCTV feed when someone goes past the motion detector which is next to the CCTV.
The video is then sent to me via Telegram.
Do you want me to share the script?
Hi Metropolis, please share your script because I’m sure there are more people (like me) who want this too.
Yes please, trying to do this exact thing and having trouble.
under ā€œshell_commandā€
ipcam2_mp4: bash -x /config/shell_scripts/ipcam2_mp4.sh >> /config/temp/ipcam2.log 2>&1
under ā€œautomationā€
- alias: IPCam2 Snapshot
    platform: state
    entity_id: binary_sensor.motion_sensor_1
    to: 'on'
  - service: shell_command.ipcam2_mp4
  - service: notify.ha_telegram
      message: ''
        video:
          - file: /config/temp/output.mp4
and the script itself : shell_scripts/ipcam2_mp4.sh
#!/bin/bash
date
folder=/config/temp
id=$(date +"%y-%m-%d_%H-%M-%S")
rtsp_url=rtsp://admin:[email protected]:554/12
frames=100
fps=5
mkdir $folder
ffmpeg -y -i $rtsp_url -r $fps -frames:v $frames -vcodec copy $folder/$id.mp4
ls -lh $folder/$id.mp4 $folder/output.mp4
cp $folder/$id.mp4 $folder/output.mp4
find $folder -type f -name '*.mp4' -mtime +30 -exec rm {} \;
Please let me know if something isn’t clear :wink:
i got my automation working using this:
- id: '1532581029802'
  alias: Cam Picture Notification
    - platform: state
      entity_id: input_boolean.doorbell_boolean
      to: 'on'
#    - platform: state
#      entity_id: binary_sensor.front_door_camera_motion
#      to: 'on'
        entity_id: camera.front_door
        filename: '/config/www/images/frontdoor.jpg'
    - service: notify.home_assistant
          file: '/config/www/images/frontdoor.jpg'
        title: "Motion near the door"
        message: "Motion detected at door {{now().strftime('%H:%M %d-%m-%Y')}}"
Thanks for the example scripts! Do you guys also delete the screenshots after e.g. a week to prevent the sd card gets full? Or do you have another solution for this?
My automation only produces 1 file it keeps rewriting over the same file
@goprojojo see my script above, that’s what is being done, deleting mini-videos older than 30 days
