Hi @pnakashian,
If you have replaced the check-button-card, you will need to update the sensors to “recreate” the attributes. Simply click on the sensor and it will update, you can then hit the undo button to restore it back to your previous date. (So this process will re write the attributes twice)
You can also press hold on the sensors to manually set a time in the past
