Hi there,
let me first state I am quite new to Home Assistant and Python in general, but I’m eager to learn. So please bear with me if I’m doing something stupid.
Running Home assistant 0.106.0 on Raspberry Pi 3B
I have succesfully integrated my Roomba 960 with the Roomba integration. Standard tasks as starting to clean my house when we are not at home are working nicely.
Now I want to extend my automation and I would like to try to send some raw commands to my Roomba.
If I understand correctly I should be able to send raw commands to my Roomby by using
vacuum.send_command
From the home assitant component i see:
async def async_send_command(self, command, params=None, **kwargs):
"""Send raw command."""
_LOGGER.debug("async_send_command %s (%s), %s", command, params, kwargs)
await self.hass.async_add_job(self.vacuum.send_command, command, params)
return True
The code also includes:
async def async_turn_on(self, **kwargs):
"""Turn the vacuum on."""
await self.hass.async_add_job(self.vacuum.send_command, "start")
self._is_on = True
So I tried to send this start command via the raw command via services in developer tools with the following (as per given example, the example shown in Home Assistant is actually for a xiaomi vacuum):
vacuum.send_command
entity_id: vacuum.dusty_dave
command: "start"
Sadly this gives me an error for which I am probably to newby to understand. The following is in the logs:
send_command() takes 2 positional arguments but 3 were given
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 134, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1230, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1253, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 198, in handle_service
self._platforms.values(), func, call, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 402, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 590, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 433, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/roomba/vacuum.py", line 262, in async_send_command
TypeError: send_command() takes 2 positional arguments but 3 were given
Can somebody point me in the right direction?
Thanks in advance.
