Just got software update 3.2.9… Everything still appears to be working but can’t see any release notes for it yet
Hi @Syrius
I think your repo
jeremywillans/check-button-card has visibility_timestamp broken, there have been a few commits since e80ef56, latest commit now is 68e4549. When I switched to your repo I had already created the entities and didn’t single click the check-button entity until I had to perform maintenance today.
The entities already created from commit e80ef56 will still have visibility_timestamp attribute even after upgrading the code.
Only after single clicking the check-buttons the attribute visibility_timestamp goes away with latest code. Since the HACS plugin install for jeremywilans/check-button-card doesn’t let you choose version or commits, I reverted it manually downloading the e80ef56 .js and creating .js.gz from it in the /config/www/community/check-button-card folder. I got visibility_timestamp back now.
I’m at HA version 0.105.5 in case you don’t see an issue in your config.
/Pierre
Try using master for the version in my repo, however dont touch it if you have a workaround
I’m in the process of updating my repo to use the new timeout_timestamp option which the proper check-button-card now uses - just waiting for one last PR to be merged to fix an outstanding issue
Got some new updates coming also… Watch this space!!
First off, thank you for all the hard work.
I am trying to get this to work and having issues. I am trying to do this without docker so everything is manually installed downloaded and configured.
I have the robot-vacuum-card working. It updates with information and I can start and stop my roomba (s9+)
My issues is that the clean individual rooms is not working.
This is the contents of my secrets.yaml (maps are not working either but I will focus on that later)
vacuum_state: http://192.###.#.###:3000/api/local/info/state
vacuum_action: http://192.###.#.###:3000/api/local/action/
vacuum_verify_ssl: false
vacuum_map: http://192.###.#.###:4123/image.php
vacuum_pmap_id: 2F8WoQ#######QyOE9UA
vacuum_user_pmapv_id: 200####222327
vacuum_family: '{"region_id": "1","region_name": "Family Room","region_type": "family_room", "type": "rid"}'
vacuum_dining: '{"region_id": "9","region_name": "Dining Room","region_type": "dining_room", "type": "rid"}'
vacuum_kitchen: '{"region_id": "7","region_name": "Kitchen","region_type": "kitchen", "type": "rid"}'
vacuum_foyer: '{"region_id": "12","region_name": "Foyer","region_type": "foyer", "type": "rid"}'
vacuum_hallway: '{"region_id": "15","region_name": "Hallway","region_type": "hallway", "type": "rid"}'
vacuum_living: '{"region_id": "11","region_name": "Living Room","region_type": "living_room", "type": "rid"}'
vacuum_utility: '{"region_id": "16","region_name": "Utility","region_type": "laundry_room", "type": "rid"}'
vacuum_breakfast: '{"region_id": "17","region_name": "Breakfast Room","region_type": "breakfast_room", "type": "rid"}'
I am running rest980 and getting output that status is being run but I never see the
GET /api/local/info/state 200 100.559 ms - 3420
GET /api/local/info/state 200 100.511 ms - 3420
GET /api/local/info/state 200 100.519 ms - 3420
GET /api/local/info/state 200 100.521 ms - 3420
GET /api/local/info/state 200 100.541 ms - 3420
GET /api/local/info/state 200 100.709 ms - 3420
GET /api/local/info/state 200 100.523 ms - 3420
GET /api/local/info/state 200 100.529 ms - 3420
GET /api/local/info/state 200 100.653 ms - 3420
But I never see the /api/local/action
I have looked through the vacuum.yaml file and changed all of the section in there that refer to the different rooms. I think it comes down to the automation not firing
In looking through the code I cannot find where initiate_vacuum_clean event gets notified. What am I missing?
automation:
# Initiate Selective Room Clean
- alias: Vacuum Clean Rooms
hide_entity: true
- platform: event
event_type: initiate_vacuum_clean
- service: rest_command.vacuum_clean
data_template:
payload: >
Hi @batlin, thanks
In the Lovelace.yaml file the button card calls the Automation. Can you please check/verify that is configured correctly?
Hi there!
Very nice write up!
I have a Roomba 960 and running home assistant on a Raspberry pi 3B.
The built in Roomba component works, but I’m missing some features I would like to play with.
If I am correct this addon should work for my 960 as well right? (except room cleaning and other not supported features). I see in the readme that this is for amd64 systems only, but the following is mentioned:
Would be nice if I can get the map to work.
Furthermore, I looked into the code on github, but I cannot find if it is possible to send Raw commands?
I would like to play around with some RAW commands, because of multiple reasons:
- My base is located under a closet. I would like to get the Roomba to drive from underneath when the bin is full, so it is easier to empy. I tried using the original component with clean, but that doesn’t work as the Roomba doesn’t accept new missions when the bin in full.
- I would like to create my own “room cleaning” feature like SuperMario wants, but for that to work the Roomba needs to be able to drive said room first
I have found some commands here, I think the are for a iRobot Create 2. But it might give some pointers to additional commands?
With the original Roomba component I seem to be unable to send Raw commands (see my post here, no answers yet though)
Thanks in advance!
If you use HA (formerly HASS) the addon works on RPi if you use HA Core then you will need to build the rest980 image locally as there isn’t an arm image on docker hub.
I’ll amend the readme when I get a chance!
I don’t think this is possible through rest980, but you might have more luck with the underlying Nodejs package dorita980? however I think know if that ability exists
Anyone had luck getting it to work with roomba 980?
And how to?
What are you trying to get work? I couple of the guys on here @SuperMario @ddppddpp have that model.
AFAIK live mapping working, but selective cleaning does not
hei. i istalled the hassio addon. and i get this when i try to enter blid and pw.
Failed to save addon configuration, not a valid value for dictionary value @ data[‘options’]. Got {‘BLID’: 31742416890, ‘PASSWORD’: ':1:1565096:K6DowgNVQAynokui’, ‘ROBOT_IP’: '******’, ‘FIRMWARE_VERSION’: ‘2’}
BLID: 3175000890"
PASSWORD: :1:***:K6DowgNVQAynokui
ROBOT_IP: ***********
FIRMWARE_VERSION: ‘2’
[email protected] start /usr/src/app
node ./bin/www
/usr/src/app/node_modules/dorita980/lib/v2/local.js:33
throw e;
Error: Connection refused: Not authorized
at MqttClient._handleConnack (/usr/src/app/node_modules/mqtt/lib/client.js:920:15)
at MqttClient._handlePacket (/usr/src/app/node_modules/mqtt/lib/client.js:350:12)
at work (/usr/src/app/node_modules/mqtt/lib/client.js:292:12)
at Writable.writable._write (/usr/src/app/node_modules/mqtt/lib/client.js:302:5)
at doWrite (/usr/src/app/node_modules/readable-stream/lib/_stream_writable.js:428:64)
at writeOrBuffer (/usr/src/app/node_modules/readable-stream/lib/_stream_writable.js:417:5)
at Writable.write (/usr/src/app/node_modules/readable-stream/lib/_stream_writable.js:334:11)
at TLSSocket.ondata (_stream_readable.js:558:20)
at emitOne (events.js:96:13)
at TLSSocket.emit (events.js:188:7)
at readableAddChunk (_stream_readable.js:176:18)
at TLSSocket.Readable.push (_stream_readable.js:134:10)
at TLSWrap.onread (net.js:559:20)
npm ERR! Linux 4.19.93-v7l
npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
npm ERR! node v6.17.1
npm ERR! npm v3.10.10
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start:node ./bin/www
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script ‘node ./bin/www’.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the rest980 package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node ./bin/www
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs rest980
npm ERR! Or if that isn’t available, you can get their info via:
npm ERR! npm owner ls rest980
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /usr/src/app/npm-debug.log
I don’t believe this needs quotes on the end?
The fist error is without anything.
The second post is with
I just tested on my dev HA (hass) instance, and it put single quotes around the password.
Can you try with that and see?
Thank you, the customer-button card was the issue. This wasn’t listed as a requirement in the repo so I missed it.
Glad its sorted! Apologies for the rabbit hole I’ve added that card to the prerequisite list
Thank you. I am working to also integrate my Braava M6 as well, has anyone else done both S9/i7 and Braava? Do I need to run two instances of Rest980 to get this accomplished?
I would assume so because you will need to specify seperate IP addresses for each.
Do you use my HA addon repo? I can create a second copy in my repo if that makes it easier for you?
I have actually been able to get it to work by creating a new lovelace-roomba-vacuum-card (naming it lovelace-roomba-braava-card) as well as creating a new vacuum.yaml in my packages directory and naming it braava (and then changing all vacuum references to braava references). It is working with both my s9+ and Braaava on two separate lovelace tabs. I was hoping there would be a way to only run rest980 once but you are right, each instance seems to need its own blid etc so i run it twice and specify a different port number for my braava. Works like a charm albeit a little clunky (needing to make sure i restart my rest980s after each restart of my server)
You have done a lot of great work on this and thank you!!!
Still working on how to get maps to work without docker
