Does anyone else has this Issue?
iRobot Roomba HA Integration is no longer working since update to HA 2024.2.3, Robot get discovered as new device but cannot be added (was working fine before).
I am having issues with the Roomba update after updating HA Core to 2024.2.3
I enabled debug & reloaded the integrations finding the follow errors in logs:
2024-02-25 17:45:41.985 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Matt for roomba
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 444, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/roomba/init.py”, line 40, in async_setup_entry
roomba = await hass.async_add_executor_job(
File “/usr/local/lib/python3.12/concurrent/futures/thread.py”, line 58, in run
File “/usr/local/lib/python3.12/site-packages/roombapy/roomba_factory.py”, line 14, in create_roomba
remote_client = RoombaFactory._create_remote_client(
File “/usr/local/lib/python3.12/site-packages/roombapy/roomba_factory.py”, line 21, in _create_remote_client
return RoombaRemoteClient(address=address, blid=blid, password=password)
File “/usr/local/lib/python3.12/site-packages/roombapy/remote_client.py”, line 44, in init
self.mqtt_client = self._get_mqtt_client()
File “/usr/local/lib/python3.12/site-packages/roombapy/remote_client.py”, line 103, in _get_mqtt_client
callback_api_version=mqtt.CallbackAPIVersion.VERSION1,
AttributeError: module ‘paho.mqtt.client’ has no attribute ‘CallbackAPIVersion’
2024-02-25 17:45:45.381 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Robert for roomba
Tried to upgrade to 2024.2.4,still shows that integration failed (Same as upgrading to 2024.2.3) . As soon as I downgraded back to 2024.2.2, integration showed OK (turned to be green again).I will try to preform upgrade once more.
I have it the other way round. Since two weeks, I cannot use the iRobot App anymore to command the Roomba (i7) - if and only if - the integration is active.
I can press buttons in the App, nothing is happening. If I disable the integration, the commands are working directly.
Only for the Roomba. The Braava does not have the problem.
Continuously and 60s in the settings. But this was the case before as well and I never faced any problems with that. And is working with the Braava as well.
I’m struggling to add a J9 to this integration (was replacing a I7 that was already working in addition to a Braava that was working great too). I’m on 2024.3.
Reproducible behavior:
launch integration via “ADD ENTRY”
doesn’t autodiscover, but nbd
asks for IP addr / host name (I can confirm the new robot is on the network – ironically my router’s HA integration sees the device on the network)
HA returns with “Retrieve Password” – which I supply (used Get-Roomba-Password-Cloud via dorita980)
hold button on robot down for about 10 secs (until chime), then hit enter on the IP address (also tried quick press on button, jic)
Exits with “Failed to Connect”
I have made sure not other connections to the iRobot cloud were active. I’ve rebooted the iRobot and my router, all to no avail. I’ve also upgraded and downgraded my HA core firmware. I’ve combed the community but cannot figure this out. Appreciate any suggestions.
I also have had this problem. I’m guessing there is a timing issue. I tried the process over and over and it suddenly accepted it on about the 30th try. I also mixed in a number of reboots of the roomba from time to time.
Hmm I’ve tried it 40-50 times and it’s never worked. HA does discover the device but never finds the password, nor accepts it when I type it in correctly. I’ve tried everything I can think of. Even did a rain dance
I added my Roomba 980 finally! I started the cleaning job from app and terminate the app. Then add to HA with previously extracted password.
I’ve used this instructions from github:
