Ok, I ended up going the python route so I couldn’t test your script. I had to spool up a linux container to do it as well. The roomba.py failed with ssl python exceptions on windows.
FYI, it’s not local push. That’s basically only if you use non-continuous mode, but then you can’t use the roomba app. It’s a WAF catch 22.
That doesn’t look like the updated syntax. The call is ended before the lambda arrow. Should only have 1 ) before the =>
I re-ran it again and that time it worked not sure what I was doing wrong or doing right either, But I got it thank you both for all of your help with this issue.
Have a great day.
Jimmy
