Is anyone actually using Microsoft.tts?
Hey folks,
I’m wondering if anyone is successfully using the microsoft.tts component? I just tried it, and it crashed my home assistant hard.
I added the minimal configuration in configuraiton.yaml, only specifying my api_key, and tried calling the tts.microsoft_say service in the dev-service page, passing an entity_id and a message parameter in the yaml.
I’m just trying to find a more natural sounding alternative to google.tts which I find has odd rhythms.
Well that is spooky.
VERY spooky.
That exact same thing happened to me this morning (hence my other post [Backup SD-Card Hassio on Windows?] about how good snapshots are :slight_smile:). I did almost exactly the same as you for exactly the same reason. google-tts is a bit rubbish in terms of sounding natural.
Not only did my HA crash but even though it came back onto the network I could not access it in any way. Very strange. I reinstalled and recovered form last nights backup so no real harm done but I’m glad I probably know the cause now. Well, the high level cause at least…
Well, good to know that it isn’t just my system
If any one reading this is interested, my system is running HomeAssistant 0.73.1 on Ubunutu 18.04
It turns out that my issue was I was using the API key for the wrong speech API.
I started out by trying to reproduce the calls made by the component. The first call to get the auth token was failing with a 401 unauthorized. You need to have a key for the Bing Speech API, not the Speech Services API, or the Custom Speech API (gee, thanks Microsoft, too much choice :))
Thanks for the update, I might set up another HA Pi and give it a try but I am loathe to risk my ‘operational’ system after what happened to me!
I suppose the question is, are you still using it and is it any better than Google TTS?
Bing Speech API doesn’t seem to be available any more. Is there a way to get a api key for Bing Speech API?
As of now the microsoft tts always crashes home assistant.
Same problem, Bing Speech API doesn’t appear to be available anymore
I use Amazon Polly platform and it work flawless. If you have time yoy can change the way it speeks very much, I habe not tested that feature. The first. year is free up to a limit and ones the sentences are created they can be reused for free from yourv local folder
