Is it possible to have more decision levels in esphome?
i want if relay is on/off and (dallas) temperatur between to values to do diffrent actions
someting like this
binary_sensor:
  - platform: gpio
    on_state:
      then:
        - if:
          - condition:
            id(temperature) > 100
          then:
            - switch.turn_off: relay_1
          else:
            - switch.turn_on: button.wohnzimmer_fenster_ota_update
i cant get it working
Your condition isn’t quite right, neither is your indentation, try this:
binary_sensor:
  - platform: gpio
    on_state:
      then:
        - if:
            condition:
              lambda: 'return id(temperature).state > 100;'
            then:
            else:
              - button.press: my_button
Also you cant use the switch turn on service for a button, use - button.press: my_button instead and you should be using the id of the button.
Thanks you are right the example is buggy.
The problem is the Trigger.
  • The example above Example triggers ony if the binary_sensor change but not when the Teperature is rising
if i turn the Logig to react on the Temperature like this
  - platform: dallas
    address: 0xB301145DE7EA6F28
    name: "$human_devicename Temperatur"
    on_value:
      then:
        - if: # check temperature
                  condition:
                    lambda: |-
                      if ( (x > $Temperatur_off) or (x < $Temperatur_on) ){
                      ESP_LOGD("between", "true");
                      return true;
                      } else {
                      ESP_LOGD("between", "false");
                      return false;
                  then:
                    - logger.log: "Range above $Temperatur_off or under $Temperatur_on State"
                    - if: # check if relay is on
                        condition:
                          lambda: 'return id(relay).state;' # is inverted
                        then:
                          - logger.log: "Range above $Temperatur_off and relay off"
                          - switch.turn_on: laser_cool
                          - text_sensor.template.publish:
                              state: "cool"
                        else:
                          - logger.log: "Range above $Temperatur_off and relay on"
                          # turn off all other
                          - switch.turn_on: laser_heat
                              state: "heat"
  • This Example Triggers if the Temperature change but not when then relay is toggled.
Thast what i mean at my Tpoci Question
Full Code here:
