Is it possible to know when physical button is pressed?
Does anyone know if it’s possible to determine, within a script or automation, if a physical button on a light or switch was pressed? I am trying to find a way to differentiate between a physical button press versus the associated HA light, switch, fan entity being switched on/off from HA. I would like to perform different actions based on physical switch, timer, motion, etc.
My devices are wifi Sonoff lights & switches running Tasmota & are configured as manual MQTT entities.
Maybe the answer comes down to whether or not the Tasmota firmware can be configured to send an MQTT payload when the relay is activated internally. Or is there another way, or any way?
Cheers
Nick
It’ll be integration, software and device dependent
I have been looking for that a long time for my Tasmota switches, but never found a solution.
Not sure how tasmota works but in esphome the switch is just a binary sensor. In esphome you can set automations to do what you want with it. it dosent necessarily need to control the light. It is also exposed in HA so you can use it there as well.
This is a little tentative, but look for posts about event context. Depending on your device and the integration there might be additional info to use and infer this. E.g. an event trigger has a context (you don’t have to use a state trigger — which doesn’t have a context — to detect state changes), and that may contain e.g. the user ID if someone pressed a button from the UI (I’ve seen this), or maybe you can detect that another automation triggered the state change (I’m not sure about this but might not be relevant).
Hi Pieter,
Thanks for those suggestions. They do make sense to me so i’ll send some time today investingating those possibilities.
Cheers
Nick
You’re welcome, @nickh66.
Here is a more complete example using the state_changed event. Replace light.smart_bulb_3 with some light entity you have.
- alias: "Test"
  initial_state: true
    - platform: event
      event_type: "state_changed"
      event_data:
        entity_id: light.smart_bulb_3
    - service: persistent_notification.create
        title: Test
        message: >-
          {% set user_id = trigger.event.context.user_id %}
          {% set triggered_by = (states.person | selectattr('attributes.user_id','==', user_id)) | list | first or "nobody" %}
          {% set first_name = "System" if triggered_by == "system" else state_attr(triggered_by.entity_id, "friendly_name").split()[0] %}
          {{ first_name }} switched {{ trigger.event.data.new_state.state }} {{ trigger.event.data.entity_id }}.
Output:
Relevant documentation:
You can subscribe to events for testing using the developer tools:
Resulting in, for example:
    "event_type": "state_changed",
    "data": {
        "entity_id": "light.smart_bulb_3",
        "old_state": {
            "state": "on",
            "attributes": {
                "min_mireds": 111,
                "max_mireds": 400,
                "supported_color_modes": [
                    "color_temp",
                    "hs"
                "color_mode": "hs",
                "brightness": 64,
                "hs_color": [
                    0,
                    0
                "rgb_color": [
                    255,
                    255,
                    255
                "xy_color": [
                    0.323,
                    0.329
                "current_power_w": 0,
                "daily_energy_kwh": 0.001,
                "monthly_energy_kwh": 0.006,
                "friendly_name": "Dining Room Light",
                "supported_features": 19,
                "icon": "mdi:dome-light"
            "last_changed": "2021-08-08T15:38:29.325921+00:00",
            "last_updated": "2021-08-08T15:38:29.325921+00:00",
            "context": {
                "id": "redacted",
                "parent_id": null,
                "user_id": "redacted"
        "new_state": {
            "state": "off",
            "attributes": {
                "min_mireds": 111,
                "max_mireds": 400,
                    "color_temp",
                    "hs"
            "last_changed": "2021-08-08T15:38:51.546905+00:00",
            "last_updated": "2021-08-08T15:38:51.546905+00:00",
            "context": {
                "id": "redacted",
                "parent_id": null,
    "origin": "LOCAL",
    "time_fired": "2021-08-08T15:38:51.546905+00:00",
    "context": {
        "id": "redacted",
        "parent_id": null,
That’s awesome @parautenbach love your work.
I too did some anaylsis over the weekend to understand this a little more. Built some simple automations & scripts & otherwise did some testing to see what the state_changed events would look like in different circumstances. I came up with this simple table to at least show the various combinations of id’s that would or would not be recorded.
Cheers
Nick
I put in a feature request here to add more information to context. I think we could make a lot smarter automations with a bit more information! Add more information to "context" objects
Hi there, thank you for this, unfortunately I can’t seem to get it to work, any ideas why please?
alias: _lght state 2
description: ""
triggers:
  - trigger: state
    entity_id:
      - light.texas_instruments_coordinator_sitting_room_lamps
conditions: []
actions:
  - action: persistent_notification.create
      message: >-
        {% set user_id = trigger.event.context.user_id %}  {% set triggered_by =
        | first or "nobody" %} {% set first_name = "System" if triggered_by ==
        "friendly_name").split()[0]%} {{ first_name }} switched {{
      title: Test
mode: single
What isn’t working?
Sorry that wasn’t very helpful of me was it?
The automation does trigger when I turn on or off ‘light.texas_instruments_coordinator_sitting_room_lamps’ but no persistent notification is created.
I’ve successfully created the following code with ChatGPT to achieve exactly what I needed. Now, if the sitting room lights are turned on using Alexa, an automation will automatically adjust them to 100% brightness. This is particularly useful as the lights often turn on at 0% or a low brightness following other automations, so this ensures they consistently reach full brightness
alias: Increase Brightness for Alexa Trigger
mode: single
triggers:
  - entity_id: light.texas_instruments_coordinator_sitting_room_lamps
    to: "on"
    trigger: state
conditions:
  - condition: template
    value_template: "{{ trigger.to_state.context.user_id is not none }}"
actions:
  - data:
      brightness_pct: 100
      transition: 1
    action: light.turn_on
I didn’t even think about using ChatGPT, thanks! Easily solved my configuration issue.
Just to bump this, this is great functionality but I find it difficult to use and to remember what the mappings are. I created a jinja macro that returns a friendly representation of what triggered the automation. This code can be extended if you wanted to create a macro that looks at specific user IDs as well (but I dont cover that).
Steps
  1. Create a “custom_templates” folder in the same directory as your “configuration.yaml”
  2. Create a file called “helpers.jinja”
  3. Paste the below contents into the file
{% macro triggered_by(contextid, parent_id, user_id) %}
{% if (context_id != none and parent_id == none and user_id != none) %} remote switch
{% elif (context_id != none and parent_id == none and user_id == none) %} physical switch
{% elif (context_id != none and parent_id != none and user_id == none) %} automation
{% else %} error
{% endif %}
{% endmacro %}
  1. Reload your yaml config (or reboot)
  2. Use it in an automation, see example below. Replace the trigger with anything you would like to test and then the value is set into an input_text entity so its easy to read.
alias: trigger test
description: >-
triggers:
  - entity_id:
      - switch.master_bath_vent
    enabled: true
    trigger: state
conditions: []
actions:
  - variables:
      Var_triggered_by: >-
        {% from 'helpers.jinja' import triggered_by %} {{
        triggered_by(trigger.to_state.context.id,trigger.to_state.context.parent_id,trigger.to_state.context.user_id)}}
  - action: input_text.set_value
    metadata: {}
      value: "{{var_triggered_by}}"
      entity_id: input_text.test
mode: restart
In order to use it as a condition in an automation you just need a value template like so:
condition: template
value_template: "{{var_triggered_by in (\"physical switch\",\"remote switch\")}}"
enabled: true
Does anyone know if its possible to use the context values within a value_template trigger itself? Like if a switch’s state is off and it was triggered by a physical switch?
I have developed a sensor Integration which will provide full info on who and where and when and how a device was triggered. It works with all physical devices, plus helpers, groups, and templated devices. It will inform you whether a device was triggered manually, dashboard, automation, script or scene, with Attributes detailing the name of the actual script, automation or scene, or the user. Works with all device brands, wifi or zigbee, etc.
It’s quite handy for quick debugging but it’s also quite powerful for use in automations where you want to override actions based on how a device is triggered.
I discovered there a lot things going on under the hood with HA which make it quite challenging to get accurate results, especially using just YAML. Apologies if you also read this same post on a related thread, I just want to get the word out. Hopefully someone will find this integration helpful.
