Looks like I have some progress. Even if you already managed to do this I’ll leave my version here in case someone else having the same issue.
The first thing I installed is Portainer in order to run the docker container. Then I tried to run you mentioned. But the problem is that it is set up for amd64
. Raspberry Pi is arm
architecture. Fortunately enough hub.docker.com
has a filter by the architecture and someone already forced ebusd image and adopted it for arm
… I’ve used this one https://hub.docker.com/r/lukics/ebusd-3.3.
I the Portainer chose images section choose DockerHub
for registry and type lukics/ebusd:armv7
for Image and click Pull the image
. Than in the container section click Add container
. Name somehow. ebusd
for instance. Type lukics/ebusd:armv7
in Image field. Then click publish a new network port
next to Manual network port publishing
. Type 8888 for both host and container.
In the Advanced container settings
select Interactive & TTY (-i -t)
In Restart policy choose Always
In Runtime & Resources click add device
next to devices. Type /dev/ttyUSB0
for both host and container. (actually for host it may vary depending on which port your adapter is plugged. But for me it worked with USB0).
Now you can hit Deply the container
button and see the logs if it works properly. You should be able to see the ebusd outpul in logs an run ebusctl
commands in the console.
Next if container works well you need to add fe lines to your /config/configuration.yaml
file.
Here are some docs. And here is my setup:
ebusd:
host: 127.0.0.1
circuit: 'bai'
port: 8888
monitored_conditions: ['HotWaterTemperature', 'StorageTemperature', 'DesiredStorageTemperature', 'OutdoorsTemperature', 'WaterPreasure', 'ReturnTemperature', 'DesiredFlowTemperature', 'FlowTemperature', 'Flame']
Probably now you need to reboot your home assistant. And you will be able to use these sensors.
