The only data that is saved from history is accessed in this manner (you can test these in the developer template section to see if they return a valid value):
If the above two do not work then change the number of input_datetime helpers explained as being needed below, from 2 to 4 (one for each the last time it changed to on).
The above syntax is not enough information. You would need to create at least two input_datetime helpers and write automations to populate the datetime values for each of them. One automation would be populated with the current datetime when contact_sensor_open is changed to off, and one to populate contact_sensor_closed with the current datetime when it is changed to off. If they are called:
esphome:
friendly_name: Garage Distance Sensor
esp8266:
board: d1_mini
# framework:
# version: 2.7.4
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "<redacted>"
ota:
password: "<redacted>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Distance-Sensor Fallback Hotspot"
captive_portal:
light:
- platform: neopixelbus
variant: WS2812
pin: D5
num_leds: 20
type: rgb
name: "Parking Light Indicator"
restore_mode: ALWAYS_OFF
- platform: ultrasonic
trigger_pin: D1
echo_pin: D2
unit_of_measurement: "m"
accuracy_decimals: 1
update_interval: 1s
timeout: 4.0m
pulse_time: 10us
filters:
- or:
- throttle: 300s
- delta: 5%
on_value:
then:
- if:
# show yellow if getting close to correct spot
condition:
and:
- sensor.in_range:
below: 1.50
above: 1.20
- binary_sensor.is_on:
then:
light.turn_on:
brightness: 100%
# yellow
red: 100%
green: 100%
blue: 0%
- if:
# Show Green when in right spot
condition:
and:
- sensor.in_range:
below: 1.20
above: 1.15
then:
light.turn_on:
brightness: 80%
red: 0%
green: 100%
blue: 0%
- if:
# Show Red when too far into garage
condition:
and:
- sensor.in_range:
below: 1.10
above: 0.00
then:
light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
# turn light off when door closed
condition:
then:
light.turn_off:
#binary sensors to check if door open or closed
binary_sensor:
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
inverted: True
name: "Garage Door Open Contact Sensor"
internal: False
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
inverted: True
name: "Garage Door Closed Contact Sensor"
internal: False
# Relay Switch to send the the pulse to
# the garage door opener (not exposed to HA)
switch:
- platform: gpio
pin: D7
name: "Garage Door Relay"
internal: true
minus the following since itâs uselessâŚ
# This creates the actual garage door in HA. The state is based
# on the two contact sensors. open & close actions both simply
# toggle the relay closed/open with a 0.5s pulse simulating a manual button press.
cover:
device_class: garage
name: "New Garage Door"
lambda: |-
if (id(contact_sensor_closed).state) {
return COVER_CLOSED;
} else if (id(contact_sensor_open).state) {
return COVER_OPERATION_CLOSING;
} else {
return COVER_OPERATION_OPENING;
open_action:
- switch.turn_on: relay
- delay: 0.5s
- switch.turn_off: relay
close_action:
- delay: 0.5s
I managed to figure out how to do what I wanted in ESPHome and not have to use an HA templated cover!
esphome:
friendly_name: My Garage Door
esp8266:
board: d1_mini
# Enable logging
logger:
api:
encryption:
key: "<redacted>"
ota:
password: "<redacted"
wifi:
ap:
captive_portal:
light:
variant: WS2812
pin: D5
num_leds: 20
type: rgb
trigger_pin: D1
echo_pin: D2
update_interval: 1s
timeout: 4.0m
pulse_time: 10us
filters:
- or:
- throttle: 300s
- delta: 5%
on_value:
then:
- if:
condition:
and:
- sensor.in_range:
below: 1.50
above: 1.20
then:
light.turn_on:
brightness: 100%
# yellow
red: 100%
green: 100%
blue: 0%
- if:
condition:
and:
- sensor.in_range:
below: 1.20
above: 1.15
then:
light.turn_on:
brightness: 80%
red: 0%
green: 100%
blue: 0%
- if:
condition:
and:
- sensor.in_range:
below: 1.10
above: 0.00
then:
light.turn_on:
brightness: 100%
red: 100%
green: 0%
blue: 0%
- if:
condition:
then:
light.turn_off:
# Binary sensors to check if door is open or closed
binary_sensor:
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
inverted: True
internal: False
on_press:
- cover.template.publish:
state: OPEN
current_operation: IDLE
on_release:
current_operation: CLOSING
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
inverted: True
internal: False
on_press:
state: CLOSED
on_release:
current_operation: OPENING
# Relay Switch to send the pulse to the garage door opener button
switch:
- platform: gpio
pin: D7
internal: False
# Toggle the relay with a 0.5s pulse simulating a manual button press
on_turn_on:
- delay : 500ms
## To-do as this is how my door operates:
## If I press stop while closing it reverses; If I press stop while opening it just stops!
## If id(contact_sensor_closed).state) == off AND id(contact_sensor_open).state) == off AND template_cov.current_operation is CLOSING
## Then
## cover.template.publish:
## id:template_cov
## current_operation: OPENING
## state: CLOSED
## If id(contact_sensor_closed).state) == off AND id(contact_sensor_open).state) == off AND template_cov.current_operation is OPENING
## Then
## id:template_cov
## current_operation: IDLE
## state: OPEN
# This creates the actual garage door in HA. The state is based on two contact sensors.
cover:
## To-do: Can I disable this action if current operation is OPENING?
open_action:
## To-do: Can I disable this action if current_operation is CLOSING?
close_action:
## To-do: Can I disable this action if state is OPEN or CLOSED?
stop_action:
I didnât realize the sensor was binary, and thought you would need to know when the sensor was last off, even when it was on, in which case âlast_changedâ only refers to when it was last âonâ rather than âoffâ - but evidently that is not the case. Happy to be of help!
last_changed updates whether it changed from on to off or off to on, but I only needed to care about whether last_changed to off for open is newer than any change for closed, and vice-versa. Since I know only one switch changes to on or off at a time, the template âif HA last_changed (to off) for switch x is newer than the last_changed for switch y (which would have been to off)â and therefore did not need input_numbers to remember last_changed on-off or last_changed off-on, unless of course an HA restart occurs, which could have been an issue! The ESPHome coding I figured out though negates all of what I just said! Thanks for your input, it helped get me started!
Hey quick question⌠Iâm new to all of this, and your solution looks like it will solve 95% of what I want to do. Iâm curious if you have any insight into the last 5%.
I have a driveway gate, the controller works just like a simple garage door opener. So I have two sensors just like you have, one to indicate the gate is âfully closedâ and one to indicate the gate is âfully open.â I like the logic you have to show opening and closing. Iâm curious if thereâs any way to indicate that there is a problem.
For example, if something is blocking the gate it has a pressure sensor, it will stop and/or kick back slightly if it hits something. My thought is⌠if it normally takes ~15 seconds for the gate to open or close, is it possible in HA to check the state and if itâs in Opening or Closing for more than ~20 seconds then to assume that something blocked the gate and then set a status of âerrorâ or âblockedâ or âstoppedâ or something like that?
Very much appreciate you sharing your work. Last question. Is there a reason you preferred the cover to be in ESPHome and not in Home Assistant?
Um, the cover is in HA. My first solution was a templated cover based on the inputs from the D1 Mini in ESPHome. The second is a cover entity in HA that the D1 Mini in ESPHome creates directly without using a templated cover. Without using an ESPHome device you could use the HA templated cover based on binary inputs from wherever. As for the issue of being stalled/blocked, an automation triggered by the state being opening or closing for 20 seconds then do whatever. I could see using HACS Python Scripting and this set_state.py script to change the state of the cover to Error when that happens, &/or anything else you want. When the entity later updates/changes its state, Error would be replaced by the new state.
I dont understand why you dont just use the esphome Feedback cover. If you have an open and closed binary sensor, it keeps track of the open,opening,closed,closing states very well and no need for making templates to do this. It also does a pretty good job keeping track of the actual position or % open/closed.
If you truly want to track the door states that covers the wall switch, car remotes and the obstacle sensor then you would need to use a current sensor or rotary encoder on the motor/drive train or above the door where the bar is with the spings. Short of that, your cover cant tell when the door is triggered by the obstacle sensor or a car remote untill it physical end_stop sensor is reached and then the cover updates.
The reason to put it in esphome is because esphome works independently of HA. If for whatever reason there is a breakdown with HA or the connection to HA your cover will still work. If your cover is in HA and theres a problem, lets say your out of town and a power outage causes your door to open. Having the esp be the cover and source of automations you can have it be aware of its state and close automatically. If it were in HA and the 2 cant communicate, well your door is going to be open untill HA is working again or you come home and close it.
Its always a good idea to put as much of the logic and automations on the esp directly. Splitting it up adds points of failure.
Thanks, I found and tested all the options and settled on cover: - platform: feedback. I created two new movement sensors which are the inverse of the state sensors:
No. They or any sensor can be made internal by setting the internal flag or by not specifying a name: and thus will not be exposed to HA. Their purpose here is to trigger movement which is a timed sequence: 10s would be increments of 10% every second, 20s would be 5%, 100s 1%, etc. Without those, the cover of course toggles between open and closed but with them you see opening/closing with a percentage updated every second or whatever the update frequency is set to in ESPHome.
Open contact is on: State is Open and movement sensor is off
Open contact changes to off so Closing Movement sensor is now on & state becomes Closing
Took me a while to get the logic right! Fortunately, the sensor is still on my desk so testing was easy.
Its does all of that by default already. This is why you configure an open/close duration. If the door is closed and you open it, it calculates the % open/closed based on those time durations. It already shows you opening/closing states in real-time. Hence the name âfeedbackâ
You have it configured wrong. You need to configure your external end_stops. Remove the open and close movement sensors and then set has_built_in_endstop: true
If you dont set that to true, the door cover will push a Stop cover command to try and stop the door by itself. You dont want that because the door already does that.
You were right about the stop cover command which I hadnât noticed. Adding has_built_in_endstop: true solved that. However, if I remove the movement sensors I donât see Opening/Closing xx%, only Open or Closed when my reed switches activate.
